Cactus Plants ?
Maniwaki
Interests: Narrow gauge trains.
Cactus Plants ?
Postby Maniwaki » Sat Nov 05, 2016 8:07 am
Hello there,
Where can I find cactus plants like that:
http://www.hattons.co.uk/95273/Woodland ... etail.aspx
I need a lot of them but not at this cost (it's a little bit expensive for me). It's for a GNine project.
All your replies are welcome !
Have a nice day,
Re: Cactus Plants ?
Postby rue_d_etropal » Sat Nov 05, 2016 11:20 am
A search on ebay, only came up with this alternative - Pegasus PG6507 – Large Cacti Plastic Model Kit – 13 – 50 mm, still not cheap, but as a kit can be put together in different ways. surprised there are no cheap Chinese ones, as there are plenty of palm trees available!
There is another Pegasus kit, which looks cheaper, set number 2.just search on Pegasus cactus
NotHarryPotter
Re: Cactus Plants ?
Postby NotHarryPotter » Sat Nov 05, 2016 11:26 am
For an On30 layout I carved a few from balsa. The bent arms were attached with pins. These were OK but not very strong if bumped.
Would it be more feasible to build wire armatures and coat them in No more gaps or similar. This is a process much used for making tree armatures.
Paint them green, it just might work.
Geoff :D
Geoff
Re: Cactus Plants ?
Postby Bilco » Sat Nov 05, 2016 11:32 am
Maniwaki
Re: Cactus Plants ?
Postby Maniwaki » Sat Nov 05, 2016 12:11 pm
Thanks for your help !
Have a nice day,
DieCastoms
Interests: I am 36. I've had some model trains all my life. I've rarely had a layout that worked reliably, due to the trains be second or third hand and poorly taken care of. I am now working on building a small layout with some 1-32 scale on 45mm track for standard gauge, also some 19mm track from On3 for Maine Two-Foot gauge, and possibly also some 16.5 HO gauge just because I love so much of what I see on your site
Re: Cactus Plants ?
Postby DieCastoms » Sat Nov 05, 2016 8:36 pm
make or buy two or three different shapes and use those to make a mold and then cast as many as you want in rubber. they'd bend instead of breaking and as long as the molds last you have an unlimited supply.
just an idea, hope it helps.
DC
Maniwaki
Re: Cactus Plants ?
Postby Maniwaki » Sun Nov 06, 2016 10:24 am
Another good idea ! Thanks.
Have a nice day,
Re:.
Postby KEG » Sun Nov 06, 2016 11:25 am
Re: Cactus Plants ?
Postby chris stockdale » Sun Nov 06, 2016 12:31 pm
Nice cactus Juergen!
The original post does say for Gnine.
Re: .
Postby KEG » Sun Nov 06, 2016 1:45 pm
Users browsing this forum: No registered users and 28 guests
