Experiments with tippers
Postby lesmond » Sat Aug 19, 2017 8:05 am
I've been on the lookout for tippers for some time, and can't quite find anything that suits what I'm after.
So, I decided to see what I could bodge together, and ended up (so far) with this for the tipper body:
Image2017-08-07 20.23.40 by lesmond2009, on Flickr
which is a piece of strip styrene 2" long rubber banded to a piece of wood with a curved edge and held in boiling water for half a minute or so, with one end (not yet trimmed) glued on. The "V" is about 1.5mm off centre in this one, but it will do for trials.
Next, using styrene channel, I made a small chassis. I'm not up for making consistent curved ends, so mine will have square ends with slightly rounded corners:
Image2017-08-18 15.22.59 by lesmond2009, on Flickr
The centre channel has room for two thin strips of lead inside it to add a bit of low down weight.
Next I made the bearing blocks using slightly thicker styrene strip, drilled out and with a brass bearing added. The wheels are (I think) Ratio from a badly injured, modified Hornby wagon bought for scrap:
Image2017-08-18 16.36.03 by lesmond2009, on Flickr
The bearing blocks need a lot of work - next time I'll shape them a lot better before I glue them on :( .
Next to make the other set of wheel bearings and think about how the tipper will be mounted.
One good (accidental) thing about the chassis design is that with these wheels the flanges don't protrude over the top edge of the base, so flat bodies etc can also be added, making it quite versatile.
southpier
Re: Experiments with tippers
Postby southpier » Sat Aug 19, 2017 12:10 pm
that looks very serviceable.
Q: the brass bearings - is this something readily available as an individual part?
thanks
Postby PeterH » Sat Aug 19, 2017 9:27 pm
That tipper looks great Les. I'll be interested to see how you resolve the bits at each end to hold and rotate the body.
Some time ago I saw on the internet a way of forming the bodies in one hit:
- underneath is some plywood with a rectangular hole the size of the body at the top
- on top a piece of styrene that has been heated till soft
- plunge down into the hole a length of wood with the end shaped to the inside of the tipper body.
I haven't tried this myself.
Postby lesmond » Sun Aug 20, 2017 8:52 pm
southpier - thank you. The bearings were from an Ebay seller, listing here:
http://www.ebay.co.uk/itm/50-OO-HO-gaug ... 2749.l2649
As usual, I've no connection to them apart from being all pleased with these bearings :). They seem readily available, and 50 will last me for a while.
Peter - also thank you. I've read of that method of making the tippers, but also haven't tried it. More below about the rotating bits and pieces.
I did a google image search for "narrow gauge tippers" and found lots of detail of the means of tipping them out. Of all of them, this one:
ImageIMG_1352 by lesmond2009, on Flickr
caught my eye for simplicity. I'm indebted to Tom Bell (Tebee) for the photograph.
Basically someone shoves the tipper body over from the opposite side that the load is needed, it rolls over until the curved section on the end of the body hits the stop attached to the frame, and presumably once empty tips back again and locates on the pin in the middle. This seems fairly simple to recreate, so I came up with this on top of the frame (I'll explain the bit over the axleboxes below):
Image2017-08-19 18.59.35 by lesmond2009, on Flickr
There needs to be 1/2mm or so more of a space between the upright bits, as they ended up slightly splayed, although this hopefully won't be noticed once its painted / weathered.
Next I needed the curved sections on the tipper itself. One quick hoke in the parts box, and I came up with this part (highlighted in red) from an unbuilt Airfix / Dapol water tower kit:
Imagetower2 by lesmond2009, on Flickr
I cut it in half, and fixed each half to one end of the tipper. In "travel" mode it looks like this:
Image2017-08-19 19.00.28 by lesmond2009, on Flickr
and like this tipped:
Image2017-08-19 19.00.56 by lesmond2009, on Flickr
The boards covering the axleboxes are allegedly to keep dirt / muck / tipped product out of the bearings, but in reality are because I made a total hash of the axleboxes and the more I tried to fix them (once attached) the worse they became. So to save a lot of bother, I hid them :).
I still need to make the couplers and mountings (link and pin in my case), but it wouldn't be the end of the world to add a Kadee or similar.
Hopefully this explains the process. The mk2 will be similar but hopefully a bit neater. I've eight to make for Gn15, and ten or so for G9, so all being well they will improve with practice :)
southpier
Postby southpier » Mon Aug 21, 2017 9:14 am
that is all looking quite nice. thanks for the bearing link.
Kerluk
Postby Kerluk » Mon Aug 21, 2017 4:23 pm
Very good work as always Is. In fact I'm a bit jealous. :mrgreen:
Postby lesmond » Mon Aug 21, 2017 8:22 pm
Thank you Chris :). Get yourself some cheap styrene and see what happens...
As the illustrious Prof. Kyzylr always signs off with:
"aim to improve"
Postby PeterH » Mon Aug 21, 2017 8:56 pm
Ha. Nice solution to the tipper problem. And to the axlebox problem.
I've found a good way to make well-shaped axleboxes is to take a length of tube and glue to it a length of strip (for the top surface). Then glue paper over the two to hide the gap between the tube and the strip. Finally, cut to short lengths with a piercing saw.
I've done this with a metal tube (for parallel bearings), paper glued round the tube to build up the size, stripwood and thin cardboard. Fast and all are the same size. You should be able to do this with styrene.
Postby docnjoj » Tue Aug 22, 2017 12:29 pm
PeterH wrote:Ha. Nice solution to the tipper problem. And to the axlebox problem.
This sounds great but I am having a hard time visualizing it. Can you post a picture perhaps?
Thanks
Postby PeterH » Wed Aug 23, 2017 2:27 am
Here's what I meant:
I make the whole thing wider than I want, then put a spacer against each side of the tube in turn and use a knife to cut it to the right width. Use a fine piercing saw blade, this cuts the bearings to length without tearing the cardboard.
Postby lesmond » Wed Aug 23, 2017 11:52 am
That's an excellent idea, Peter - thanks for the diagram. As you said, that is do-able in styrene.
southpier
Postby southpier » Wed Aug 23, 2017 12:15 pm
I can see making these in length and slicing them "bologna-style" for multiple runs. line up on the frames with a piece of axle or brass rod so they would be perpendicular to the center axis and parallel to each other.
Postby docnjoj » Wed Aug 23, 2017 1:15 pm
Thanks Peter. That makes it very clear and very smart too.
Postby Bilco » Wed Aug 23, 2017 4:28 pm
When I was building tipping skips for Wood Bros I made Hudson-like axle boxes from a length of square-section plastic rod with a hole through the centre. I glued a piece to a strip of plasticard cut to the required width, and sliced it into sections. The bonus was that pin-point bearings are a push fit into the hole ...
There is a thread about the whole skip project, but all the photos have been 'bucked' ...
Postby Bilco » Wed Aug 23, 2017 6:18 pm
This is the thread about my skips - and some photos are still visible, for some reason ...
http://forum.gn15.info/viewtopic.php?t= ... skips+hard
This was the tipping arm - unpainted ...
... three skips, showing the finished axlebox ...
... and the bent bit of wire wot did the tipping ...
