Back once again!
Robatron86
Interests: Models, Music and Motors
Back once again!
Postby Robatron86 » Mon Feb 05, 2018 3:06 pm
Hello all I am back!
After a long period away, I have returned to Gn15. I have sold off all my American stock and decided to give the large scale a go again.
I have refurbished my critter and started building a open wagon.
The layout is 4ft by 18 inches and will use a turntable to save space.
Re: Back once again!
Postby chris stockdale » Mon Feb 05, 2018 4:15 pm
Hi Rob,
Good to have you back.
A question if I may: I see you are using Photobucket, does that mean you are paying them a fortune or might your images suddenly vanish as they have for so many others?
Robatron86
Postby Robatron86 » Mon Feb 05, 2018 7:01 pm
Thank you Chris.
I do have a premium account with Photobucket, but I pay no subscription.
I hadn't really questioned it until now.
southpier
Postby southpier » Tue Feb 06, 2018 12:46 am
looks like the trackplan will give you some variety & continuous running.
Postby Jon Randall » Wed Feb 07, 2018 4:52 pm
Looks good Rob
Robatron86
Postby Robatron86 » Thu Mar 01, 2018 8:28 pm
Thanks everyone. The loop has been laid.
Robatron86
Postby Robatron86 » Fri Mar 23, 2018 3:05 pm
Afternoon everyone. I have progressed a bit further with this. All the track has been laid, wired and tested.
The next step is to give it all a blast with some muck and then ballasting the lot.
Postby Jon Randall » Fri Mar 23, 2018 10:13 pm
That looks a good trackplan, I'll have to remember it. 8)
Robatron86
Postby Robatron86 » Sat Mar 24, 2018 12:41 am
Thanks Jon. Feel free to use it :)
I have also done some detail work on the critter.
Robatron86
Postby Robatron86 » Fri Mar 30, 2018 7:23 pm
I was able to get the track sprayed this afternoon.
I used Humbrol Dark Earth acrylic spray.
Postby chris69 » Fri Mar 30, 2018 8:15 pm
Looking really good!
What radius did you end up using?
Happy Easter
Robatron86
Postby Robatron86 » Fri Mar 30, 2018 8:43 pm
Thanks Chris. I went with 6 inch radius at both ends.
Postby chris69 » Sat Mar 31, 2018 4:42 am
Thanks, appreciate it!
best
Robatron86
Postby Robatron86 » Mon Apr 02, 2018 9:47 pm
Some structures are now appearing on the layout. The engine shed will be part of a larger workshop of sorts, which will be low relief in front of the rear part of the loop.
The back of the engine shed will be curved to follow the curve of the loop to make it look like it isn't a roundy roundy. I hope that makes sense.
The fuel tank is a left over from my HO days. It will receive larger diameter pipe work than it has now.
