Stackpole
dijon
Stackpole
Postby dijon » Mon Jan 21, 2019 3:13 pm
I'm new here, I hope this works!
Stackpole
From time to time I get tempted away into “little distractions”. Some, such as Billy Spanners’ Garage and Y Cob-Bach, can be incorporated into the railway, some are heretical and many are irrelevant. Rhyd having hit an impasse for the moment with a solution reminiscent to trying to row across a river with a fox, a chicken and a sack if grain my mind wandered.
I have long been attracted to the Minimum Gauge Railways of Sir Arthur Heywood and my first Gn15 model (although I did not know it by that name then) was built over 26 years ago. It is an itch that has long needed scratching.
So the Stackpole project was born. Hopefully a series of linkable dioramas that will be developed as and when. But first a little reality.
Stackpole Estate
ImageSTACKPOLETIMELINE by davidphillipjohn, on Flickr
The Palladian spender of Stackpole Court in its heyday.
The Stackpole Estate is about three miles south-west of Pembroke, on the south coast of the Angle Peninsula. It was a huge estate for the area, over 15,000 acres at its maximum.
Elizabeth Lort was the heiress of the Stackpole Estate and she married Alexander Campbell of Cawdor in 1689. The Campbells built the early Georgian mansion of Stackpole Court in the Palladian style in the 1730s on the site of the earlier fortified house.
Sir John Campbell II inherited the estate in 1777 and began landscaping work on a grand scale. What was once a valley was later flooded to create the Bosherston Lakes, as part of a designed landscape, and thousands of trees were planted.
It was a grand place in the ownership of a rich and influential family.
In my version of reality the sixth Sir John was very friendly with the Duke of Westminster who introduced him to, and to the works of, Sir Arthur Heywood. Sir John’s plans were to build, essentially two, but connected, railways: one entirely functional, connecting Stackpole Quay, the village, the Court, the Walled Garden and Home Farm, the other for the convenience of shooting guests – taking them from the Court out to St Govan’s Head and the shoots out beyond Castlemartin.
Imagerailwayline by davidphillipjohn, on Flickr
A “working” map of the system, the westward line across the shoot would have carried on for another four miles or so.
Back to reality, two World Wars heralded a century of decline at Stackpole. Half of the estate, around 6,000 acres, was requisitioned by the Ministry of Defence to form Castlemartin Range in 1938. Soldiers billeted in Stackpole Court caused devastating damage to the house by stripping lead from the roof, causing dry and wet rot. Sadly, the house was finally demolished in 1963 to avoid death duties. In 1976 what was left of this historic estate was broken up and the farms were sold. Thankfully the coast, woods and lakes passed to the National Trust and were saved.
8 Arch Bridge
ImageStackpole-Estate-1957 by davidphillipjohn, on Flickr
The eight arch bridge at Stackpole, it is across here that this bit of imaginary line is running.
I just wanted a setting for me to photograph models as they emerge so this is not really a diorama or even a photo-plank – just a set.
As a base I used the back of a MFI type drawer. The only 16.5mm track I had was a length of PECO 00 so I cut away every other sleeper – they are far too small for 1/24th scale – I used Evo-stick to fix this and built up the road base either side with 3mm foam sheet (fixed with UHU Por).
When this was dry the roadway was covered with Redutex 7mm scale weather grey paving and the edges touched in with a grey Promarker to get rid of the stark white edge. The track was dressed with PECO coarse grey ballast fixed with Ballast Bind and put to one-side to dry for a couple of days.
ImageStaBas01 by davidphillipjohn, on Flickr
ImageStaBas02 by davidphillipjohn, on Flickr
Meanwhile the wall was constructed. This was cut from the hardboard drawer bottom, so fitted neatly into the slot in the drawer side. This was backed with 10mm bluefoam and covered with Noch textured Granite Stone paper. The cap stones were cut individual from blue foam and then painted to match and when dry the ensemble was sprayed with Dullcoate.
ImageStaBas03 by davidphillipjohn, on Flickr
ImageStaBas04 by davidphillipjohn, on Flickr
ImageStaBas05 by davidphillipjohn, on Flickr
ImageStaBas06 by davidphillipjohn, on Flickr
Finally, for now, a couple of Smallbrook wagons posed on the bridge, grass, weed and backscene to come!
ImageStaBas07 by davidphillipjohn, on Flickr
TrainsOnArran
Re: Stackpole
Postby TrainsOnArran » Mon Jan 21, 2019 5:47 pm
As a recent convert to Gn15 and estate railways (see Cordale Hall Railway), I’m looking forward to seeing your dioramas develop.
Please keep posting pictures.
Re: Stackpole
Postby PeterH » Mon Jan 21, 2019 8:48 pm
Nice work. If you model those cannons you can more than scratch your itch.
Re: Stackpole
Postby chris stockdale » Tue Jan 22, 2019 10:33 am
For the past ten or so years we have rented a cottage near Strumble Head and we’ve visited Stackpole several times. Once we were lucky enough to see an otter in the lily ponds.
Since much of the path around the ponds is level I’ve often thought that a narrow gauge line could (should?) have been part of the estate.
Looking forward to seeing the diorames develop.
dijon
Re: Stackpole
Postby dijon » Wed Jan 23, 2019 12:03 pm
Thanks to a follower's early intervention the wall has now been rebuilt with all stones the right-way-up as shown in this photo taken by a recent tourist!
ImageIMG_4007 by davidphillipjohn, on Flickr
Thanks for the comments - and particularly tp Neil.
dijon
Re: Stackpole
Postby dijon » Thu Jan 24, 2019 3:04 pm
Letting the Grass Grow
Now the wall has been rebuilt I have been getting on with the base layer of grass. I am looking for a well kept but not immaculate standard of grounds maintenance – there were an awful lot of grounds to maintain! This 18th Century engraving of the 8 Arch Bridge should show what I mean.
Image8Arch18thC by davidphillipjohn, on Flickr
I got this far with my Greenescene static grass machine, meaning to add a few blades of taller grass and some leaves when ...
ImageIMG_4015 by davidphillipjohn, on Flickr
ImageIMG_4018 by davidphillipjohn, on Flickr
ImageIMG_4020 by davidphillipjohn, on Flickr
... the backscene arrived.
Now, this had been sent off to John at ID Backscenes as a black and white JPEG file and it arrived back the right size and in full colour: I reckon magic was involved. So I had to stop what I was doing and play with the backscene – and here we are.
ImageIMG_4013 by davidphillipjohn, on Flickr
ImageIMG_4012 by davidphillipjohn, on Flickr
Very many thanks to John - info@art-printers.com
dijon
Re: Stackpole
Postby dijon » Tue Jan 29, 2019 10:54 am
Steam arrives at Stackpole
The Campbells of Cawdor had long been supporters of railway development, John, the First Earl, was involved in the building of his first railway in 1828, from the Llangennech Coal Company mines to the coast near Llanelly.. Fredrick, Lord Emlyn, he succeeded his father in 1898 to become the 3rd Earl) was the Chairman of the GWR from 1895 to 1905
In my version, with all his interests and contacts in railways, and having seen the estate railway of his friend the Duke of Westminster at Eaton Hall, he built his own, grander, railway at Stackpole.
He was succeeded by his eldest son, Hugh Frederick Vaughan Campbell, who changed the family residence to Cawdor Castle in Nairnshire and Golden Grove in Carmarthenshire.
Back to the make believe, Hugh’s younger brother, John, remained at Stackpole, both to run their interests in west Wales and to keep the Estate for the various family visits.
John had inherited his father’s love of railways and took great delight in the running of the Stackpole Railway to the principles of Sir Arthur Heywood, his guide and mentor who he met during the building of his father’s railway.
ImageIMG_4042 by davidphillipjohn, on Flickr
ImageIMG_4044 by davidphillipjohn, on Flickr
Here we see JESSICA, transferred from Berger Hall, undergoing trials across the 8 Arch Bridge, in the Stackpole Railway.
Thanks Bill
Re: Stackpole
Postby PeterH » Tue Jan 29, 2019 8:23 pm
Good to see some motive power. What is the original of the photo in the backscene? Did the printer hand colour it to turn it from black and white to colour?
dijon
Re: Stackpole
Postby dijon » Wed Jan 30, 2019 9:50 am
The backscene original I found in a photographic archuve. I would guess John (ID Backscenes) coloured it using some digital wizardry as he sent me three copies, but exactky what or how I don't know.
David
dijon
Re: Stackpole
Postby dijon » Fri Feb 01, 2019 12:18 pm
The Decauville Coach
Thanks for all the likes and comments. I’m learning as much as you! Before we start on the coach, the 8 Arch Bridge base is finished with grass and weeds added.
ImageIMG_4069 by davidphillipjohn, on Flickr
Many years ago I drew up a Decauville 4w coach; in fact I made a 16mm model. Unfortunately I can find neither the original drawing nor photos of that model.
ImageDecCoach by davidphillipjohn, on Flickr
And I wanted one for the Stackpole Railway. The obvious starting point was the Smallbrooj Studios kit ( http://smallbrookstudio.co.uk/kits-part ... h/11151500).
To the resin chassis I added a wooden floor ...
ImageIMG_4047 by davidphillipjohn, on Flickr
... followed by angle irons along the sides.
ImageIMG_4051 by davidphillipjohn, on Flickr
The ends had been sprayed and glazing fitted before being fixed to the chassis. I to better position the roof I added angle strips to the inside of the roof end beams ...
ImageIMG_4063 by davidphillipjohn, on Flickr
. unfortunately this had the effect of splaying the ends ...
ImageIMG_4062 by davidphillipjohn, on Flickr
... if I was to do it again I would pack out the floor with 40thou plasticard at each end. Live and learn. I removed the angles and just glued the roof in place.
I made up, and narrowed, a pair of Phoenix Castings 1/24th Garden Benches ...
ImageIMG_4071 by davidphillipjohn, on Flickr
... which were sprayed the main body colour.
ImageIMG_4081 by davidphillipjohn, on Flickr
To be continued ...
ImageIMG_4083 by davidphillipjohn, on Flickr
(Is that chimney wonky or is it just the photograph? I’ll go and check that!)
dijon
Re: Stackpole
Postby dijon » Sat Feb 02, 2019 1:16 pm
Two things from yesterday were annoying me. So the wonky chimney is sorted and we seem to be must free. Although I have no idea wha,t or how, the fogginess appeared. I can’t believe the iPhone could be affected by internal condensation and there was nothing on the lens – but it was bloody cold in the workshop compared to the house, where the phone had been overnight. So was that it?
ImageIMG_4087 by davidphillipjohn, on Flickr
ImageIMG_4090 by davidphillipjohn, on Flickr
Still, all’s well now.
David
dijon
Re: Stackpole
Postby dijon » Wed Feb 06, 2019 3:23 pm
The Boat Train
Image3rdEarl by davidphillipjohn, on Flickr
[i ]The 3rd Earl of Cawdor[/i]
We have seen the 3ed Earl Cawdor was a railway supporter and enthusiast. Indeed, during his tenure as Chairman of the GWR he, personally, bought the Refreshment Rooms at Swindon so he could relieve the Company of its obligation to stop all trains for a 10 minute refreshment stop. Thus speeding up the rail service between London, Bristol, Cardiff and places beyond. The GWR recognised him by naming a locomotive “Earl of Cawdor”.
Image3297 Earl Cawdor, Westbourne Park, 1903 by davidphillipjohn, on Flickr
His enthusiasm (in my world) also led to the development of his own railway at the Stackpole Estate, as both a functioning transport system within the Estate and an amusement for visitors on shooting or scenic trips. The original intention was to connect the Estate to the GWR Tenby and Pembroke line at Lamphey but the First World War intervened and the rapid development of road transport finally killed off the idea.
His second son, John Pryce Vaughan Campbell, very much brought up as the “Spare “ rather than the “Heir”, took a personal interest in the development of the railway but was not beyond teasing his eminent father. The Earl had a passion for sailing and maintained at yacht, the Speedwhitch, at Stackpole Quay. So John Pryce decided to give his father a Boat Train.
A suitable design was found in the catalogue of the French manufacturer, Decauville et Fils, ...
ImageDecauville Coach by davidphillipjohn, on Flickr
... from which the Estate workshops built this ...
ImageIMG_4100 by davidphillipjohn, on Flickr
... and here it is , in The Boat Train, running out towards Linney Head.
ImageIMG_4109 by davidphillipjohn, on Flickr
ImageIMG_4110 by davidphillipjohn, on Flickr
ImageIMG_4112 by davidphillipjohn, on Flickr
David
dijon
Re: Stackpole
Postby dijon » Mon Feb 18, 2019 12:51 pm
Just another break in the wall.
I have always liked Heywood’s 4w brake van for Eaton Hall and in 1981 I was lucky enough to gain access to measure it in York Railway Museum - apologies these drawings had appeared quite recently on here as part of Bilco’s thread “Making a Brake for it” and I gratefully acknowledge Bill’s woek as being the impetus for my build.
ImageA11a by davidphillipjohn, on Flickr
ImageA11b by davidphillipjohn, on Flickr
The starting point was a Smallbrook Heywood wagon chassis, beefed up with Plastruct sections.
ImageIMG_4055 by davidphillipjohn, on Flickr
ImageIMG_4058 by davidphillipjohn, on Flickr
Then scribing some 80thou plasticard for the sides, making sure to treat both sides the same to prevent warping. I then made a simple jig from card and timber off-cuts to ensure both sides were identical. The square posts are 3.2mm section – with the ‘chamfers’ around the side panels.
ImageIMG_4103 by davidphillipjohn, on Flickr
The sides were then fixed to the chassis
ImageIMG_4105 by davidphillipjohn, on Flickr
ImageIMG_4106 by davidphillipjohn, on Flickr
I constructwd the seats and back-rest from scrap plasticard. Left the whole lot overnight to dry thoroughly and then carefully sanded the seat section to be an exact fit between the sides.
ImageIMG_4115 by davidphillipjohn, on Flickr
I then fixed the framing around the drop down flap that forms the seat front (allowing for the thickness of the floor). Floor boards were cut from 5mm x 1.5mm timber strip from my local model shop and stained with my usual Promarkers. The body was given a couple of coats of Tamiya Red Bown spray and then the floor boards were fitted.
ImageIMG_4128 by davidphillipjohn, on Flickr
ImageIMG_4129 by davidphillipjohn, on Flickr
End rails were bent up and a brake handle made from bits of wire and tube.
ImageIMG_4196 by davidphillipjohn, on Flickr
A roof was made up using a pre-formed roof section available from the 7mm NGA and platicard arcs cut with a compass cutter. Here is the sub-assembly sprayed; it is left as loose fitting.
ImageIMG_4200 by davidphillipjohn, on Flickr
Iron banding round the floor boards was made from plastic section and a representation of the drop-down flap handle was pained and glued in place.
ImageIMG_4208 by davidphillipjohn, on Flickr ImageIMG_4209 by davidphillipjohn, on Flickr
When it stops raining I will give it a mist of Dullcote.
ImageIMG_4215 by davidphillipjohn, on Flickr
Because I am a responsible researcher I never tried climbing in to the barke-van to test the sitting position – but the model would suggest someone a lot more flexible than this Preiser would be needed!
ImageIMG_4212 by davidphillipjohn, on Flickr
With sincere thanks to Bilco for all his help and advice – and to Harris the cat.
David
Re: Stackpole
Postby Bilco » Mon Feb 18, 2019 2:10 pm
Thank you for making the drawing available to me, David - it was a great help!
Re: Stackpole
Postby Thorness » Mon Feb 18, 2019 3:50 pm
Bit late to the party!
This is the one at Eaton in 2014:
ImageEaton Hall Railway by Thorness, on Flickr
dijon
Re: Stackpole
Postby dijon » Fri Feb 22, 2019 2:28 pm
Eaton Hall 1 ton wagon
Along with the Eaton Hall Brake Van I measured in 1981 (see above) there was also a Small 1 Ton wagon – which I eventually got round to drawing in 1991.
ImageEaton Hall Railway by davidphillipjohn, on Flickr
On a recent visit to Shapeways I noticed they had a very similar wagon, drawn by KeenEye Models and described as “1:24 Heywood 2x4 Basic Car Frame w/ Heywood Couplers”, so I ordered one. A “top” is also available for this wagon – next time!
The print that arrived was very nice indeed. Couplers were already attached and with axle boxes and Sir Arthur’s special ‘choppers’ for his couplings. The angle-iron frame for the floor boards is a separate print. As is my usual approach the prints were immersed in a bath of white spirit (turpentine substitute) for 24 hours; then they were given a gentle wash with Cif and an old toothbrush and finally given a good rinse in warm water and left to dry. The prints required very little smoothing.
The wagon’s frames are hollow inverted “U” shapes, so I filled them with Liquid Gravity held in place with a 50/50 mix of Copydex and water with just a dash of washing-up liquid. Again left overnight to dry.
ImageIMG_4207 by davidphillipjohn, on Flickr
To give a better surface to glue the floor-boards, I levelled the frame tops with Green Stuff and when that was dry sanded it back to a smooth finish.
ImageIMG_4216 by davidphillipjohn, on Flickr
The axle boxes have long ‘pips’ which fit into holes in the frames (as can be seen above), so I just pushed these in place before spraying the whole assembly. This means once the paint is dry the axle boxes can be easily removed, leaving the mating surface unpainted – to allow the glue to hold things firmly at a later stage.
ImageIMG_4218 by davidphillipjohn, on Flickr
I did this because I was not certain that if the axleboxes were firmly glued in place before painting that I would be able to flex the frames enough to insert the wheels without damaging something. So the pre-painted wheels were placed in the axleboxes which, in turn, were place in their mounting holes in the frames but with nothing push home.
ImageIMG_4222 by davidphillipjohn, on Flickr
This then allowed me to put a spot of superglue under each axlebox and push everytning firmly in place.
ImageIMG_4223 by davidphillipjohn, on Flickr
The “choppers” wre fitted to the couplings with a brass pin with the end bent over. I then cut and stained the floor-boards, placed them in the angle-iron frame and glued them to the chassis.
ImageIMG_4231 by davidphillipjohn, on Flickr
Once dry, the frame was removed, the planks tidied up, the frame coloured with a Woodland Scenics “Rusty Rail” pen before gluing it back in place.
ImageIMG_4234 by davidphillipjohn, on Flickr
ImageIMG_4236 by davidphillipjohn, on Flickr
And here she is in a train.
ImageIMG_4233 by davidphillipjohn, on Flickr
The Smallbrook kits make it easy (too easy?) to fit Kadee couplings – they work well but look awful! So I decided to mount the Haywood couplings on another wagon – and although they look good I am not sure they will cope with the excruraitingly tight curves I am going to have to adopt off-stage (well actually I am certain!). So as an experiment I mounted the Kadees under the Haywood’s. The choppers don;t couple (they would cause problems if they dud) but they are what you see, while the Kadees still do the work.
ImageIMG_4239 by davidphillipjohn, on Flickr
Is it a worthwhile addition? What do you think? Is there something better I could mount in the NEM pockets?
ImageIMG_4240 by davidphillipjohn, on Flickr
And finally (a lot of home-work this week) how do you guys feel about these “blow-by-blow” build posts – keep them, only show the tricky bits, or cut straight to the finished models? Please let me know.
David
Re: Stackpole
Postby PeterH » Fri Feb 22, 2019 6:54 pm
Nice wagons. And a great idea to change locations by swapping the backscene.
I like the blow-by-blow posts myself. I enjoy seeing how others do it and I learn other ways to make things. Though it emphasises how slowly I model.
Re: Stackpole
Postby Jon Randall » Thu Feb 28, 2019 5:35 pm
I agree with the blow by blow posts being a great way, we all learn things from time to time.
Excellent modelling David 8)
dijon
Re: Stackpole
Postby dijon » Thu Jul 18, 2019 1:39 pm
Paving the Way
Work has started on the first “station” on the Stackpole Railway, Greenbridge Lodge, a sort of picnic site for the family and watering hole for the shooting parties. The plan is that the track in this area will be inset; so I purchased one of the 0n30 paver rollers from Rails n Scale’s Shapeways’ shop.
I soaked the roller overnight in white-spirit followed by a gentle scrub in warm soapy water. I spread DAS clay over a section of track, rolled the roller and the result was awful. The roller picked up the clay from between the rails and ... well, messy all around.
After a good wash down I had another go, better but still not good. Another scrub down, but I had learned some lessons.
Third attempt the track was fixed firmly in place.
ImageIMG_4757 by davidphillipjohn, on Flickr
The track was then filled, to over rail height, with DAS clay, firmly pressed down. This was then covered with grease-proof paper and pressed down to rail level with the firm application of a rolling pin. (Looking at the photo more care should have been taken to get a smoother surface.)
ImageIMG_4759 by davidphillipjohn, on Flickr
The roller was dunked in a 50% mix of washing up liquid and water, with the same solution brushed over the track. The roller was then pushed along using a spindle through the centre to increase downward pressure.
ImageIMG_4762 by davidphillipjohn, on Flickr
When dry the rail tops were cleaned (must do better next time!) and the whole thing given a coat of medium grey. That was followed by a Woodland Scenics Track Pen to rust the rail and the “girder rail”.
ImageIMG_4764 by davidphillipjohn, on Flickr
And when that was dry I applied some weathering.
ImageIMG_4767 by davidphillipjohn, on Flickr
Relatively pleased. The secret seems to be to get a good, even surface before the roller is applied and use plenty of soapy water to keep roller and Das from clinging to each other. The rolling pin definitely helped and I have a wallpaper seam roller coming. If that makes things better I’ll let you know. (I do wish I had paid more attention to the outside of the rails!)
The first building for Greenbridge Lode is almost finished - a sort of staff/railwayman’s room, with a loo at the back.
ImageIMG_4770 by davidphillipjohn, on Flickr
ImageIMG_4772 by davidphillipjohn, on Flickr
David
Re: Stackpole
Postby PeterH » Sat Jul 20, 2019 9:12 pm
Nice pavers.
dijon
Re: Stackpole
Postby dijon » Wed Jul 31, 2019 5:04 pm
And so it begins ...
The first of the buildings for Greenbridge Lodge is now finished (apart from internal detailing). It is, as some of you have already spotted, the Petite Properties 1/24th scale Wash-house and WC. It has been modified with wooden lintels, stone sills and a new “signal-box” style end-window, as befits the private railway of the Chairman of the GWR!
The brick paper is a lovely embossed card, the slate and ridge tiles are via e-bay, not cheap but superb. Weathering is paint, felt-tip and coloured pencil – as the layout is, primarily, set between 1915 and 1920 the weathering might be a little heavy, the railway had only just been built then, but that headland is a harsh environment!
The first picture shows a work’s train, the gardeners are obviously off somewhere while the supervisor enjoys the sun.
ImageIMG_4795 by davidphillipjohn, on Flickr
ImageIMG_4800 by davidphillipjohn, on Flickr
And when all the activity has calmed down, Harris the cat, sits on the windowsill enjoying the last of the day’s rays.
ImageIMG_4806 by davidphillipjohn, on Flickr
The lodge itself should be next but the baseboard materials are arriving on Wednesday!
Dvid
Re: Stackpole
Postby Jon Randall » Fri Aug 02, 2019 3:58 pm
Very smart 8)
RoGNer
Re: Stackpole
Postby RoGNer » Thu Aug 08, 2019 10:34 am
8) Wow! Excellent work! Keep the pictures coming, looks superb
Roger
dijon
Re: Stackpole
Postby dijon » Wed Mar 11, 2020 10:18 am
ST PETROX
ImageIMG_5664 by davidphillipjohn, on Flickr
Since I first came across the railways of Sir Arthur Heywood in the mid-1970s I have been a fan. Circumstances contrived for me to meet the late Duke of Westminster across his Eaton Hall brake van and, in 1982, I was lucky enough to get an invitation to look round the Estate at Eaton Hall and discover what was left of the railway.
I drew up a good number of what I saw and some (the remaining ones) are in my ‘Various Drawings’ thread. Although I have built a couple of vehicles over the years I never got round to seriously modelling Heywood.
Then someone gave me a sneak preview of the (then) forthcoming RCL book and I decided to take the plunge and the fiction of the Stackpole Estate Railway was born: see previous posts.
At about the same time I took ownership of JESICA from the Berger Hall Railway. She was a lovely model, a Smallbrook KATIE, lovingly built by Bill Corser (Bilco of this parish) in the way that only he can. The thread describing his build of his first loco KAFFIE can be found here http://ngrm-online.com/forums/index.php ... direction/.
The RCL book then came out and was everything I had been led to believe, and more, as a result plans for the Stackpole Railway firmed up and JESICA was sent off to Chris Clark for on new paint job more in the Heywood style.
ImageIMG_5689 by davidphillipjohn, on Flickr
The fourth Earl of Cawdor and his sin, John, pose for the official photograph of ST PETROX
ImageIMG_5675 by davidphillipjohn, on Flickr
ST PETROX hauling the Boat Train for the first time...
ImageIMG_5671 by davidphillipjohn, on Flickr
... and then in service helping the gardeners ...
ImageIMG_5681 by davidphillipjohn, on Flickr
... and collecting fire wood ...
ImageIMG_5683 by davidphillipjohn, on Flickr
... and finally we leave Sir John having a chat with Huw Pugh, ST PETROX‘s driver at Stackpole.
(St Petrox is the named saint of one of two parish churches on the Stackpole Estate and the Campbells of Cawdor were patrons of both.)
With thanks to Bill Corser, Chris Clark and Roy Link for their input and to Bob (Blackcloud) for providing another scenic base. More pictures on the Flickr sire,
David
DCRFAN 3
Re: Stackpole
Postby DCRFAN 3 » Thu Mar 12, 2020 8:06 am
St Petrox really looks the part. :D
