Postby PeterH » Mon Jan 28, 2019 9:30 pm
Yes, I’ve seen that kit on another forum, and it seems a great start for a layout.
You can sometimes convert an 00 scale model to G by increasing the size of the doors and windows. In this case the low building in the middle at the bottom might be too low; also the conveyor? on the right above the track would probably need raising. You might need to buy two kits and cut them up to get enough parts.
In G scale a printed building can look a bit flat. Modellers often glue card frames around doors and windows to make it a bit 3D.
