Estate Elongate
Estate Elongate
Postby Bilco » Sat Sep 14, 2019 7:04 pm
Right - the New Phase of Berger Hall - Elongation ....
The plan is to have the railway running through a bit of estate scenery, with the Stable Yard scene as one end of an out-and-back layout ...
Building the new baseboards, using the tried and tested hardboard base with layers of 50mm insulating foam sheets topped with 5mm black foam board. From the left - the hardboard base with half inch wooden boards at the ends; the board with two layers of insulation foam sheets; the existing bit ...
The 'male' end board, with the joining dowels inboard of the two rare earth magnets ...
The 'female' end board with the two brass sockets for the joining dowels, inboard of two 25mm steel washers for the magnets to stick onto ...
The completed boards joined to the Stable Yard board. The left-hand board has the 3mm hardboard backscene bent by my usual method - soak the hardboard with water at the point of bending, clamp it round a suitable former (in this case a 2 litre paint tin), and wait for the water to dry thoroughly. There will be an exit hole at the left end where the track joins the fiddle yard. This is the yet to be constructed Rotaverser Mk II. The Mk I is dismantled and in bits in the back of the garage ...
Hours of fun ...
AndyB
Interests: Gn15, 'O' Gauge, O14
Re: Estate Elongate
Postby AndyB » Tue Sep 17, 2019 2:50 pm
that looks very good... I like the idea of using the magnets to hold the boards together!
Like it! :D
Regards
Andy
regards Andy
Clear Desk, Sick Mind...
Those who have a clear desk will never know the joy of finding something they thought they had lost a long time ago.
Re: Estate Elongate
Postby chris69 » Wed Sep 18, 2019 8:43 pm
Great Idea!
That may give me the chance to expand my planned layout. I am restricted by the room available on the shelf. But I have enough room in separate areas, so on occasion the 2 could be married....
thanks, for this idea!
I' keep reading...
Re: Estate Elongate
Postby Bilco » Thu Oct 03, 2019 6:12 pm
Right - the two new boards have the backscenes sky-painted, and track laid ...
The rather ugly jiggle in the inner track of the loop arises because:-
a) I want to use the track bits I have in stock
b) I want the tracks to cross the baseboard join at right-angles
c) Rule One applies ...
I have also constructed Rotaverser Mk II ...
I have made the top rectangular so that the tracks on it will be straight - there'll be 4 of them, when I get round to laying them ...
An edge-on view of Rotaverser Mk II shows that there are 4 layers this time. The base has the drawer runners running from front to rear, as with the Mk I - the lead-screw has been recycled: the next layer has a large-radius pivot: the next layer has drawer runners running left-right, with the top layer on ... er ... top. The second set of runners is so that the top can be moved away from the baseboard to allow it to rotate. More magnets will be employed to keep the top layer in contact with the baseboard - to be fitted.
Rotaverser MkI is now a few bits at the back of the garage - I recycled the track on the left-hand baseboard.
What reverse curves?
Re: Estate Elongate
Postby Bilco » Fri Oct 04, 2019 4:31 pm
Isn't it funny how you see things in a photo of your model that you completely miss when looking at the real thing?
After my post yesterday I looked at the photos along the baseboards, and at the 'ugly jiggle'. Suddenly, the thought struck that, if I reversed the length of track between the Y point and the baseboard join, the jiggle would go away ...
... so I did, and it did ...
Now all I need to do is ballast, paint the track, start the land-forming ...
Hours of fun ...
Re: Estate Elongate
Postby chris stockdale » Fri Oct 04, 2019 5:17 pm
Hi Bill,
Things are already looking interesting...
Unless I’ve missed it, I don’t think you’ve said what size these new and old chunks are, do say please.
Re: Estate Elongate
Postby Bilco » Sat Oct 05, 2019 4:09 pm
Hi Stockers,
The original board is 24" x 18", the two new ones are 24" x 14", and the Rotaverser Mk II is 14" x 18" ...
So, the overall length is 7' 6" ...
Re: Estate Elongate
Postby chris stockdale » Sat Oct 05, 2019 4:16 pm
Thanks Bill, that really helps to visualise it that much better. Onward!
Gnu Bee
Re: Estate Elongate
Postby Gnu Bee » Mon Oct 14, 2019 5:17 pm
I notice you are using foam board as a base - how do you fix the flexible track so it doesn't creep back to straight while the glue goes off.
Re: Estate Elongate
Postby Bilco » Tue Oct 15, 2019 7:22 am
Hi Geoff,
Basically, the rails are pre-bent so that there is no tendency to straighten. I use Woodland Scenics glue to stick the track down, and put weights on it until the glue is set. It seems to stay down well, although it can be unstuck easily by sliding a thin blade under the sleepers!
Re: Estate Elongate
Postby Bilco » Sun Oct 20, 2019 3:50 pm
So, just over two weeks since the last update - it feels longer ...
I've finally finished painting and ballasting the track ...
The track is mainly* Peco code 100 Streamline. I moved the sleepers into pairs and spaced them out, then stuck them down - that was the easy part ...
I needed to fill in the little gaps between the pairs of sleepers - then paint them and the track - then weather the sleepers - then ballast - then clean and test ...
I now need to visit my osteopath to get my back straight again ...
* I also used some Peco Set Track 14" radius curves - the small ones, about 3" long. The rails were taken off the sleeper base and the spare sleepers from the Streamline track slid on ...
Anyway, things still run after a stint of winkling the odd bits of ballast out of the rails and cleaning the paint off the rail tops ...
Next up - landforming ...
Hours of fun ...
Re: Estate Elongate
Postby Bilco » Sat Nov 02, 2019 1:57 pm
The first stage of landforming is complete ...
... looking along the layout. The lumps at the far end will be hidden by walls and covered with trees ...
The right-hand end - undulations front to back required the most earth moving during Stackers' ground prep. (OK, Stackers just stood by and shouted while others actually shifted the earth ...)
The left end. A slight down-slope towards the front, and the rise beyond it ...
A view of the frontage, showing the undulations ...
The rises are made from more of the Celotex foam - actually, it's not the stuff I used before, as Wickes don't have the small sheets, and an 8' x 4' sheet is a bit more than I need. I got this lot from Jewsons - it's white rather than yellow, and it doesn't have the bands of fibreglass needles which do such a good job of blunting the knifeblade when you cut it ...
I have also used some patching plaster to fair in the foam and coat it where needed. Then all was sanded - outside in a strong wind. The old lady at the other end of the village will be complaining about the mysterious dust on her washing again ...
We're off to the Devonshire coast on Monday, so things will be on hold for a week, then back to work on the next stage ...
Re: Estate Elongate
Postby Bilco » Thu Nov 14, 2019 4:54 pm
The next stage of landforming - painting the areas to be grassed or treed ...
I use acrylic modelling paste with acrylic colouring to give a sealing coat over the insulation foam - it's got a bit of flexibility, too ...
The walls at the far end have been built with black foam core and await covering with stone paper ...
Hours of fun ...
Re: Estate Elongate
Postby Bilco » Fri Nov 29, 2019 12:32 pm
Another two weeks gone - how did that happen ...
Anyway, the far walls have now been stoned ...
I've been thinking on how to continue the walls that came to an abrupt end on the left side of the original scene ...
The wall and trees at the left end were attached to Rotaverser Mk 1, and are now in the pile of remnants at the back of the garage. After some experimentation I've come up with these ...
At the back the wall has been continued into a small building - bothy? - in the same brickwork. The trees in the backscene will be extended in due course ...
At the front that board with the trees and wall has been replaced with this little bit of stonework, just propped in place at the moment ...
The new bits front and back are designed to fit together with the old bits when the boards are joined up ...
I must get round to making a start on grassing up the landscape - hours of fun ...
DCRFAN 3
Re: Estate Elongate
Postby DCRFAN 3 » Sun Dec 01, 2019 5:40 am
Looking good. Time does rush by but every bit of progress helps achieve your goal.
Re: Estate Elongate
Postby Bilco » Sat Dec 07, 2019 4:13 pm
... but before grassing can start I needed to stick on the photo backdrop trees ...
Left end (please excuse the unsharp image)
Middle ...
... and up to the Stable yard entrance...
I still need to do a bit of blending; the visible horizontal joins are only in the sections where there will be 3D trees in front of the photographic ones, so with any luck they'll be hidden. I had to join up bits to get the height I wanted - I'm reusing the photo backdrops I took for the original Berger Hall ...
Next up is the promised grassing ... but Mrs Bilco is already making 'clear the dining table for Christmas dinner' noises, so I'll have to get a move on ...
Hours of fun ...
Re: Estate Elongate
Postby chris stockdale » Tue Dec 10, 2019 11:03 am
Hi Bill,
I’ve just popped back to the top of the thread and read it all through again. It’s all coming together very well.
Every time I read the word Rotaverser it makes me grin - both inspirational and amusing in one package, what more can one ask? :D
Re: Estate Elongate
Postby Bilco » Wed Dec 18, 2019 2:50 pm
Just in time to get the dining table cleared before Mrs Bilco starts making pointed comments ...
... the first layer of 2mm flock (or 'Basing Layer' as wwscenics.com says) is down and other ground cover done ...
I made some Heywood-style point levers - there is one stuck down by the entrance to the Stable Yard, and the extended sleepers are in position for the two outside ones - just waiting for the paint to dry ...
Happy Christmas and great modelling sessions in 2020 ...
Remote1
Location: Ascot, but on another planet according to some
Interests: Narrow gauge
Re: Estate Elongate
Postby Remote1 » Wed Dec 18, 2019 3:17 pm
Where's the like button? Excellent!
Season's Greetings to you as well.
Steve
Steve
Modelling skills on order..........
TrainsOnArran
Re: Estate Elongate
Postby TrainsOnArran » Wed Dec 18, 2019 5:01 pm
That is looking very good indeed.
Re: Estate Elongate
Postby Bilco » Sun Dec 22, 2019 11:20 am
The last, snatched, shot of 2019, while Mrs Bilco's attention is elsewhere ...
Just to see if the scene is coming together - a rail enthusiast waiting for a train to exit the Stable Yard ...
"Yes, of course I'm clearing the dining table Dear - just another couple of minutes ...."
Happy Christmas ...
