Page 8 of 8
Re: A New Foreign Layout
Posted: Thu Nov 08, 2018 4:35 am
DSC_0105 (2).JPG (1.81 MiB) Viewed 1262 times
Fruits of the day's labours. Found some ballast, sitting on the workbench right in front of me, so the turnout got the treatment. While the matte medium was out, some enhancements were made to some of the scenic items. The quay got some anchor rings (fencing staples, of all things), and I made up some looped ropes to go on the boat to hold it fast (it's been held slow ever since DCR built it). At the moment, I'm trying to finish off all the 'little' things... need to wait until I'm back at work, and can access the Model Shop to get church bits.
Posted: Fri Nov 09, 2018 7:39 am
One of the features I put on the layout when I first got it, were diode controlled safety blocks at the ends of the line to avoid 'high dives' onto the floor.
So, today's job, a bit of wiring. First, take out the diode, and close up the joint, from the end that is now continuing to the next board. This time, there are two end sidings to rig up. Being clever, in my own mind, I decided to apply the gaps on the same sides of each of the tracks. That way, I could take a feed off one line (making sure it was one that was not going to be affected by isolating points). From this feed, I soldered in the diode (dry testing, first, of course.... wasn't born yesterday). Off the other leg of the diode, came two wires, one to each of the isolated dead end sections of track. Worked well, first time. Second time, didn't work well, in fact, didn't work at all. Jump wire testing identified the culprit wire. It was one that I 'forced' through the baseboard... turns out I'd actually broken it. Quickly replaced, and all's good.
Lesson, if it don't fit, don't force it (somewhat contrary to the usually good ol' Kiwi slogan).
Posted: Sat Nov 10, 2018 4:04 am
DSC_0104 (2).JPG (2.33 MiB) Viewed 1188 times
It appears that this photo is hiding back on the previous page, and has only had 2 views. Since I particularly like this, and am sure you will too, I've republished it for all to enjoy.
Posted: Sun Nov 11, 2018 6:54 am
A setback in proceedings.... the skyboard, only 6mm thick, and only with one brace, has warped.
New thicker one called for.
Posted: Thu Nov 15, 2018 6:19 am
DSC_0112 (2).JPG (2.37 MiB) Viewed 1098 times
First undercoat has gone on. As usual, this finds all the 'spots to fill', and firry bits to sand back.
Let it dry, and that's tomorrow's job.
Played around with the static grass, too. Picked up on another layout by accident, that if you spray the grass with hairspray and very lightly sprinke over some 'scatter' material, you can get realistic seed heads on your foliage.
Posted: Thu Nov 15, 2018 6:43 am
by DCRFAN 3
Thats looking real nice.
Posted: Sat Nov 17, 2018 3:24 am
DSC_0113 (2).JPG (1.96 MiB) Viewed 1048 times
Just about what the punters will see. Roof will be imitation lead sheet.... add ribs every 3 feet or so, paint lead colour.
The lead/grey trim came about by default. I'd tried painting the window sills, but didn't work out. So I scraped the paint off, exposing the original plastic casting, so grey it is. Fortunately, I'd only tack hot glued the door in the frame, so that came out easily. Double fortunate, I had a spare door, unpainted, in stock.
Posted: Sun Nov 18, 2018 6:05 am
Roof now marked out for the 'lead ribs'. Just the pencil lines give a good impression of the final outcome. Stripwood, or plastic, from the model shop tomorrow, and a 'lead looking' paint from the rattle can place.
And, all this by the way, is only one of 5 layouts that I will be showing.
Posted: Mon Nov 19, 2018 8:10 am
Roof ribbed. Painting tomorrow night.
Posted: Wed Nov 21, 2018 7:04 am
Gavin Sowry wrote:Roof ribbed. Painting tomorrow night.
Tomorrow, been and gone. The church is finished (apart from a small paint touch up).
I'm happy with it.... 48 hours to show set up.
Tried doing the roof with Tamyia Gun Metal. This colour had potential, a nice uneven drying metallicy shine, but it was going to take forever with a brush, and try as damn, couldn't get straightlines even on the edges. Wiped it off, and resprayed white. Ended up using a same brand as the white, but it said red (even though it is a dull copper brown) primer. Photo when the paint finally drys.
Posted: Wed Nov 21, 2018 7:38 am
Voila!
Paint still wet, and a few blemishes, but, she'll be right on the night.
Posted: Thu Nov 22, 2018 8:41 am
Gavin Sowry wrote:
Voila!
On the night before the night, she's all right.
Oversprays, and slight paint run all sanded back and touched up.
Anchored to the foundation.
Posted: Fri Nov 23, 2018 6:38 am
Survived transport to Rail-Ex, and met with the necessary oohs and aahs from members of the engineering fraternity. So, I'm happy.
Another layout had some wires disconnect, but that's fixed, and it's all go for the show.
Posted: Fri Nov 23, 2018 9:42 am
by nu2ng
Good luck with the show Gavin :)
Posted: Sat Nov 24, 2018 4:42 am
No description really necessary.
Posted: Sat Nov 24, 2018 7:45 am
Looking very smart.
A nice light, bright venue too. All too often it’s somewhere with just electric light, perhaps a litte gloomy, and thus not great for photography here in the UK.
Posted: Sat Nov 24, 2018 8:31 am
chris stockdale wrote:Looking very smart.
The 'English' conditions were outside.... it was raining.
For once, the Wellington Garden Railway Group running day was not affected by the weather... that's them on Court 2.
Posted: Mon Nov 26, 2018 7:28 pm
Don't it really get to you.
I had all sorts of bother on doing an English roof for the church before settling on the easiest option (well, it had to be finished for the show).
Finally get something acceptable, and go on show.
Walk across the hall to one of the traders...and there in stamped plastic sheet, is every style, and scale, of roofing imaginable, and, only $2.00 more than the styrene strips I had to buy for the church.
Posted: Thu Nov 29, 2018 6:12 am
Bonus, the layout, in one piece, can fit through the awkward doorways into my train shed.
Posted: Wed Dec 05, 2018 7:04 am
https://www.youtube.com/watch?v=j6Ylni2esRs
Finally, someone has posted the video. Check out around the 22-23 minute mark.
