Newland's Farm
Rex Ashton
Interests: Modelling something different
Newland's Farm
Postby Rex Ashton » Sun Sep 12, 2010 3:18 pm
Hi everybody. Not been a member for long but I thought I'd let you know where I've got to. It's all Alexander Losch's fault for building F. Huber & Son - lovely layout - but I don't think I'm the first to be mightily impressed with his modelling.
For longer than I care to think about I've been tempted to build something along the lines of the Lincolnshire Potato Railways so here goes.
Having a spare 4'x2' board pointed me in the direction of Alex's Barwurz & Co but as you can see from my plan I rarther liked the turntable from Huber - might all end up being a bit tight though, we'll see.
I'm afraid I'm going to be a bit boring with the first loco and put a Sidelines conversion onto a Bachmann mechanical. It runs well, comes dcc fitted and I've already got one (Hopefully it will get a Loksound Micro chip in it). As you can see I've reworked the bonnet as many others have done and I'm eagerly awaiting a parcel from Steve with the rest of the bits.
Gnot only am I new to Gn15, I'm also a recent DCC convert. Does anyone know how to wire up the sector plate because as far as I can see the polarity has to be reversed when it's aligned with the fiddleyard. I guess the same applies if the turtable is rotated through 360 degrees - any help would be much appreciated.
I'm hoping to have the layout in my local exhibition in February and I'll hopefully keep a progress report going on here.
NarrowGauge
Interests: All things Narrow Gauge
Postby NarrowGauge » Mon Sep 13, 2010 12:19 am
Since you are using DCC you will need to install 1 "reverse loop module" between the main track feed and the sector plate rails and a second "reverse loop module" between the main track feed and the turntable rails.
You can use any brand. I have used the Digitrax one and it works fine with both my Bachmann DCC Controller (Like the one you have) and it works fine with my NCE Controller.
for more info about the Digitrax one look at this link http://www.digitrax.com/prd_powerman_ar1.php
I hope this helps
Tess
You Can't Have Everything .... Where Would You Put It
http://trainsbytess.blogspot.com/
NarrowGauge
Postby NarrowGauge » Mon Sep 13, 2010 12:22 am
Oh I also forgot to say. I don't believe that these modules will work with Normal DC. So all your locos must be DCC Chipped (even thought your controller will support 1 DC Loco).
Tess
Rex Ashton
Newland's Farm
Postby Rex Ashton » Mon Sep 13, 2010 7:41 am
Hi Tess
Thanks for the info. The Bachmann controller is an Ebay cheapie to test things out. The intention will be to use the NCE Powercab - Father Christmass willing!.
Charlie Stewart
Postby Charlie Stewart » Mon Sep 13, 2010 5:53 pm
Hello Rex & welcome, Can I please ask for some more info on those v-skips in your first photo Please???
Good luck with the turntable..... for an alternative to the reversing modules see my post My Bodger Turntable......It works!!!
which I used on my previous layout the sunshine orange co.
Charlie
My YouTube videos
light travels faster than sound... thats why some people appear bright until they open their mouth!!!
Postby Glen A » Mon Sep 13, 2010 8:47 pm
Great job on the interesting track design Rex.
That should give you a variety of operational possibilities.
Rex Ashton
Newlads's Farm
Postby Rex Ashton » Tue Sep 14, 2010 7:46 am
Hi Charlie
The V skips are actually 0n30 ones produced some time ago by 'American Model Builders Inc'. I don't know whether they're still available or not. They are whitemetal kits with vacuum formed skips. Maybe a bit small for Gn15 but they might work. I've had a quick look at your article re the turntable - seems like it might be the answr. Thanks.
Rex Ashton
Newlands Farm
Postby Rex Ashton » Wed Sep 22, 2010 5:59 pm
Hi All
By way of an update. The bits have come from Steve Bennett to complete the Davenport conversion. The loco's in the paintshops at the moment so I'll post photos as soon as. I've made a start on the main buildings as well and I'm realising just how big this 1:22.5 scale stuff is now!
Does anyone out there do a good English Garden Wall bond brickwork that I could use or am I looking at producing my own or possibly using seperate bricks? Any info would be very welcome.
Ken Hamilton
Interests: 1/2" scale Narrow Gauge, 1/25th-scale model cars; Writing; Photography; Hots Rods
Postby Ken Hamilton » Wed Sep 22, 2010 7:16 pm
That's a neat little layout design. Looks like it'll be a lot of fun!
I look forward to more progress pictures.
Re: Newlands Farm
Postby Gerry Bullock » Wed Sep 22, 2010 8:40 pm
Rex Ashton wrote:Hi All
Interesting layout Rex.
Bromley Craft products produce a range of brickwork stencils in 1/24 scale, however I'm not sure whether the bond you mention is offered.
Postby Artizen » Wed Sep 22, 2010 10:30 pm
It's all Nick Ogden's fault really (on FinescaleRR forum). He made a beautiful little diorama in 1:32 using individual bricks so I am today in the process of gluing down all 104 brick shaped bits of styrene to make a silicone mould so I can make bricks out of casting plaster and concrete oxides so I can a) get the colours I want and need - and b) so I can get some realism into the layout with brick walls etc. I thought briefly about scribing foamcore or DAS clay etc but in the end Nick's diorama won me over. Time consuming and a little bit mad but then, it's your layout and only you know what level of realism you are happy with. There are a couple of suppliers of 1:24 scale bricks out there but at a cost that was just too high for me to justify. If you reallly really want English garden wall bond design, then you will need to create it yourself - all the brick slips used on dolls houses are common bond that I have seen. Garden bond is peculiar to the UK. If you decide to do it with individual bricks, please write about it on this thread so I can see how other Gnutters go about it!!!!!! LOL :D
Postby michael » Wed Sep 22, 2010 11:04 pm
I know the feeling Ian, try tin ceiling tiles :(
Rex Ashton
Newland's Farm
Postby Rex Ashton » Tue Nov 30, 2010 9:43 am
Hi Everyone.
As I've not posted for a while I thought I'd better update.
The original idea was based on The Lincolnshire Potato Railways but it's now looking more like Oxfordshire fruit farm.
I decided - based on some comments - that the trackplan was going to be a bit tricky (electrically) as it included a reverse loop and a turntable so I've simplified things a bit in that operationally it will be operated as an end to end and the turntable will act more as a sector plate - it won't go 360 degrees.
The buildings are progressing and I've resolved the brickwork issue by doing my own a la Pendon - time consuming but very rewarding.
The Bachmann Davenport conversion is finished and I'm very pleased and I've done the wire frames for two small trees. Pictures to follow as soon as I've done them.
Postby Artizen » Tue Nov 30, 2010 11:33 am
I've been really busy with Christmas sales, post Christmas sales, NYE lottery, Back to School and Valentine's Day stuff recently so I have only managed to make 4980 bricks so far (since 20 October). Mad really. Still redesigning the building so I can take it with me on holiday on Saturday. Telly is even more boring at the coast for some reason.
Postby Willow Creek Traction » Tue Nov 30, 2010 6:37 pm
Dang, been on Farcebook too much, am looking for the "Like" button :lol:
Rex Ashton
Newland's Farm
Postby Rex Ashton » Wed Dec 01, 2010 3:12 pm
As promised, I've managed to do some pics.
This photo shows my attempt at brickwork. The bricks have been drawn out on watercolour paper and scribed. A mortar wash was then brushed over the sheet using craft acrylic paint. After this had dried the bricks were individually painted using artists watercolours (Light Red, Raw Sienna and Burnt Umber) a random effect being created by varying the shades. It's very time consuming and I've done about 25 hours up to now!!!!!
A slightly wider view of the buildings. Ths basic shell is 3mm MDF. The side wall of the leanto will be finished in brick with a slate or tile roof. The taller barn is going to be done with wavey edge lapboard and fnished off with a thatched roof.
I've started two small trees to balance out the left hand end of the layout and conceal the exit to the fiddle yard at the back. The frames are made from soft wire (supplied by Greenscene) and covered with several coats of that company's 'Texture Bark'. Once they've been painted the foliage will mbe added using Woodland Scenics materials.
That's progress to date. Back to the brickwork!
Postby Artizen » Wed Dec 01, 2010 9:33 pm
I assume the garden wall is done in garden wall bond? :) Your labour of love with the bricks is very gnice but how do you create a feeling of depth in 3D on the surface?
Rex Ashton
Newland's farm
Postby Rex Ashton » Thu Dec 02, 2010 8:04 am
Artizen wrote:I assume the garden wall is done in garden wall bond? :) Your labour of love with the bricks is very gnice but how do you create a feeling of depth in 3D on the surface?
Hi Ian.
The wall is, to the best of my knowledge right. It has three rows of stretchers with one of headers. The relief is created by scribing the mortar lines into the paper before painting and the paper itself gives a nice feel to the bricks themselves. At normal viewig distances this looks fine. Assuming a scale of 1:24 (ish) a half inch deep mortar line is about half a millimeter.
Postby dieselwater » Fri Dec 03, 2010 6:01 pm
The layout is shaping up Gnicely. The bricks are excellent.
Korschtal
Postby Korschtal » Fri Dec 03, 2010 7:58 pm
You've more patience than me with wall building, which is probably why your wall looks like a wall, and my last attempt looked like a piece of card with bricks painted on it... Very nice.
Andy in Stuttgart
www.korschtal.wordpress.com
Postby michael » Sat Dec 04, 2010 6:41 am
Nice job on the bricks Rex, I sympathize with you regarding the time to do bricks. Ask me how I gnow. :wink:
Rex Ashton
Postby Rex Ashton » Sat Dec 04, 2010 9:22 am
Hi All.
Thanks for the encouraging comments.
Korschtal wrote:my last attempt looked like a piece of card with bricks painted on it... Very nice.
Andy. Not that I'm any sort of expert but the secret seems to be scribing the mortar lines. The paint seems to stay within the brick rather than migrating into the mortar - or have I just been lucky? :?
Michael wrote:Nice job on the bricks Rex, I sympathize with you regarding the time to do bricks. Ask me how I gnow.
Michael. I guess you've done a few (lots!) then? :wink:
Rex Ashton
Newland's Farm
Postby Rex Ashton » Mon Feb 20, 2012 5:01 pm
Hi everbody.
It's been a while and the layout is coming on nicely - not fast enough though. Most of the basics are done and it's going to my local club exhibition this weekend www.nmdrm.co.uk/nextexhibition.html
Hopefully when the panic's off I'll be able to do a proper update and post some more piccies - might even get the layout finished as well!
Below is a recent photo of some of the progress so far.
If anyone's at the show, please come and make yourself known.
Postby Little Andi. » Mon Feb 20, 2012 6:14 pm
You have got a lot further than me in the same time frame - It looks really good ........ and I'm looking forward to those further pic's you've now promised - :D
Moronguhl
Postby Moronguhl » Thu Feb 23, 2012 12:18 pm
Definitely, this looks fantastic so far, more pics please!
Christian Summers
