The spring steel strip is the pick up for the axles, and brass tubes fit on the axles to maintain the axles in position.
Here the bogie has been reassembled. The screw provides location for the wheel wipers. The clearance between the nut and the spring steel is small, so a piece of insulation tape has been used.
[Edited to correct picture links 1/10/15]
