MacFeegles Distillery
backwaterscotland
Interests: Emett-esque GN15
Postby backwaterscotland » Thu Mar 15, 2012 9:30 am
Hi Folks,
Having spend quite a while wandering the forum looking for ideas and inspiration, I have now made a start on a layout of my own. The main inspiration came from "Makers Mark Distillery" (http://gn15.info/forum/viewtopic.php?t=6313) with a bit of "Upton Whent"
My plan is to model part of a Scottish Distillery with the classic white-washed stone buildings. I know that many of the Scottish distilleries had standard gauge railway lines but I thought narrow gauge might be a bit far fetched - but I was wrong! Talisker distillery on the Isle of Skye had a 2-foot gauge line from the pier to the distillery which was horse drawn and later used a tractor. I may extend this layout at some point to include the pier as a destination - there are some good photos of the track remains on the pier here : http://hlrco.wordpress.com/scottish-narrow-gauge/constructed-lines/talisker-distillery-tramway/
As you may spot from the image above and from the name, there will be a certain amount of fantasy with references to Terry Pratchett's Discworld books including the Nac Mac Feegles and at least one swamp dragon.
Andy 8)
Last edited by backwaterscotland on Tue Mar 03, 2015 7:26 pm, edited 3 times in total.
backwaterscotland
Postby backwaterscotland » Thu Mar 15, 2012 9:37 am
This is not my first layout (although the first in Gn15) and I've built quite a few baseboards for a group project recently so the board for this layout will be the same construction. Board size is 3'x2' and is made from 9mm plywood with a 75mm deep "spaced" frame. There will be a central strut fitted once the point motor locations have been worked out
On top there is a 1/8" sheet of cork as a base.
Trackplan is simple, an inglenook with the central siding looped around to the make a circle. The track to the front is taken to the board edge to allow for an extension to be added later. All track in Peco 0-16.5 Code 100.
Current progress is that the track is laid, the point motors installed (but not yet wired) and the basic wiring to the track installed and tested.
Next up will be designing the buildings and building some stock.
Andy 8)
Wesleyb
Interests: Anything narrow guage aswell as O scale Dioramas
Postby Wesleyb » Thu Mar 15, 2012 12:35 pm
Im in the process of planning my very first Gn15 layout aswell Andy.
So ill be following your progress all the way.
Regards
Wes
Postby Steve Bennett » Thu Mar 15, 2012 12:48 pm
Nice bit of woodwork there Andy.
My one concern looking at the track, is how close it is to the edges at either end. If the ends are going to be open, any knocks of the table/stand at an exhibition could send your stock to the floor. If you plan to have walls at the ends, I'm not sure you have left enough clearance, it looks like it will be a bit tight.
Thought it worth mentioning before you go any further.
backwaterscotland
Postby backwaterscotland » Thu Mar 15, 2012 9:47 pm
Steve Bennett wrote:Nice bit of woodwork there Andy.
Thanks Steve :)
I had been looking at the edges and realised that I'd made a mistake. My plan was for 10mm clearance at either end but I forgot to allow for the wagon overhang when I laid the track :oops:
The track on the left has now been made into a tighter radius which gives me my 10mm clearance (as there will be a wall & gate on that side), the one on the right only has about 5mm but I'll live with that as it will be inside a building.
Andy 8)
Gavin Sowry
Postby Gavin Sowry » Fri Mar 16, 2012 7:33 am
:shock: Safe bet, closest track centreline to any edge of the baseboard should be 100mm, or 4 inches. Check out Haywards Estate in Gn15.info Layout Tours... explains all.
Gavin Sowry
Gn15 Gnu Zealand
backwaterscotland
Postby backwaterscotland » Sun Mar 25, 2012 12:17 pm
Quick update.
Track is now painted - sprayed with red oxide then matt black and the sleepers painted by hand with a suitable brown acrylic paint.
Started to mock the buildings up to get a feel for the sizes and shapes. The buildings are based on Edradour distillery (Scotland's smallest distillery - http://www.edradour.com). One error on the mockup is that the buildings on the right should have sloped roofs rather than a flat end.
Although the mockups are in foam board, I will use artists mounting board for the real buildings with a stripwood internal frame.
Andy 8)
Ian-IoM
Postby Ian-IoM » Sun Mar 25, 2012 3:50 pm
I like the distillery idea, nice distinctive buildings with their pagoda thingummies. (Nice produce too generally :roll: ).
It looks like the track near the edge of the baseboard is running by a wall, so no chance of trains falling off :)
Ian K
Be seeing you...
Postby Gerry Bullock » Sun Mar 25, 2012 4:57 pm
Great location Andy, here's another feature you might consider including:
Photographed at Edradour 3 years back.
backwaterscotland
Postby backwaterscotland » Sun Mar 25, 2012 5:28 pm
Gerry Bullock wrote:Great location Andy, here's another feature you might consider including:
Tempting :lol:
Revell do a Trabant in 1/24th which would suit although I was thinking about a Landrover instead.
Andy 8)
Narrow gauge Nutter
Postby Narrow gauge Nutter » Sun Mar 25, 2012 6:31 pm
Looking Good :wink:
Can you post some piccies of the real distillery?
Do you have anymore info on the Talisker line?
Thanks.
Keep up good work, and postings 8)
Lost in France and loving it!
backwaterscotland
Postby backwaterscotland » Sun Mar 25, 2012 6:53 pm
Narrow gauge Nutter wrote:Looking Good :wink:
Thanks.
There is a good set of photos here : http://www.fife.50megs.com/Tour%20Edradour%20Distillery%20Scotland/index.htm - I'd like to get a run up to the distillery to take some photos but time isn't there.
Unfortunately, the linked page above is all that's I've found on the talisker tramway.
Andy 8)
michik
Interests: paper models, comix, cats ...oh, and railways!
Postby michik » Mon Mar 26, 2012 3:02 pm
Ahhh, this was bound to happen sooner or later, wasn't it?
I always thought the slogans 'The dram wi' a slam' and 'A big drop fo' wee jocks' quite appropriate!
:P
Michi
ROMANES EVNT DOMVS!
...and don't drop the banana!
backwaterscotland
Postby backwaterscotland » Sun Apr 01, 2012 4:36 pm
Today I settled down to start on the buildings. The main building has had the front cut from some 3mm thick card rescued from the back of a bookcase but that is as far as progress got with that.
The smaller building has been constructed from artist mounting board and stripwood with the door and window cutouts being made thicker with some offcuts from the 3mm card as the original building had very thick walls.
The roof's did give me a bit of a headache, resorting to maths, trigonometry and bits of paper to work out the sizes and angles. These have been assembled but not yet attached.
Andy 8)
Postby Willow Creek Traction » Sun Apr 01, 2012 7:00 pm
Hey hey hey, it's taking shape :D
Postby Glen A » Sun Apr 01, 2012 7:01 pm
I didn't think the board looked very big in the early photos.
But now you see it with buildings and people for reference it is actually a good size.
You have made a good start and I'm sure you are going to turn it into a nice layout.
backwaterscotland
Postby backwaterscotland » Tue Apr 03, 2012 12:50 pm
More progress - I'm trying to keep my momentum up by doing at least a bit each day I can :D
Main building construction - 3mm card for the front, artist mounting board for the rest. 6.3mm plastruct U-section above the doors and 5mm wide card strips added under the windows as ledges. Didn't quite get the building square but I don't think anyone will notice.
Internal frame is 12mm and 8mm stripwood - there will be a floor installed in the future but not until the windows and doors are installed.
The roofs on the small building will be slate but the main building will the corrugated material as per the real one.
I've also been working on some stock using the excellent Sidelines kits. So far I've built and painted :
1 tank wagon
1 3-plank open wagon
1 flat wagon
2 "modern" flat wagons
Plus I'm working on a couple of Gnomy-based tippers.
Andy 8)
Postby demaine22 » Thu Apr 05, 2012 12:33 pm
Looks great! 8)
backwaterscotland
Postby backwaterscotland » Fri Apr 13, 2012 4:52 pm
Although it doesn't seem to have had much progress, quite a number of hours have been put in :shock:
All of the buildings have had mounting board "concrete" installed where it would be visible - this has taken quite a while as fitting the card around the tracks is fiddly and needs to be precise.
Doors have been made and painted - shown temporarily fitted.
Beginnings of the scenics have begun - the plan is for a tarmac/gravel road from back left to the front right while the tracks will have low grassed areas around them. I've also added a disconnected line at the front which will be heavily overgrown to suggest that the line originally went further into the distillery but has been cut back.
Andy 8)
Tomo
Postby Tomo » Sat Apr 14, 2012 2:30 am
Clever placement and use of styrofoam
backwaterscotland
Postby backwaterscotland » Sun Apr 15, 2012 6:35 pm
Had the landscapers in over the weekend :lol:
The roadway has been built up using black mounting board but this will need some weathering and toning down.
The styrofoam/polystyrene has gone as it was too tall and looked wrong. I had bought some hanging basket liner last week and the previous pack I used was a couple of mm thick but the new lot I bought is about 8mm thick so I've removed the polystyrene and replaced it with the liner. On top of this I'll use some static grass.
A good day's work - I like it when there is lots of visible progress :D
Andy 8)
backwaterscotland
Postby backwaterscotland » Wed May 09, 2012 3:31 pm
Update time.
The roadway has been completed with a top coat of "road grey" materials to give a rough gravel/tarmac look.
The main building has been painted, glued into position and the doors glued on. The smaller building has been painted and is awaiting the doors and window to be glued on. A delivery of 1/24th scale slates has been delivered so slating will start shortly.
The left hand end of the layout has progressed as well with the installation of walls (modified stonecast items by Ten Commandments) and gate posts (8mm stripwood painted and weathered). Gates are still to be made though.
Andy 8)
Postby Glen A » Wed May 09, 2012 6:59 pm
Its looking really good Andy.
You might wish to try glueing a few little grass tufts into the track at the front to make it look a little more disused.
backwaterscotland
Postby backwaterscotland » Wed May 09, 2012 7:25 pm
Glen A wrote:Its looking really good Andy.
Thanks Glen,
I've still got a lot of the scenics to complete including improving the grass with some 6mm static grass at which point I'll add some tufts and some dandelions.
Andy 8)
Postby Steve Bennett » Thu May 10, 2012 9:44 am
Really coming together well Andy and I really like the way that despite a lot of buildings, you still have lots of space outside to create the scene.
Plenty of scope for detailing, even after the bare bones of the layout are completed to a standard suitable to show. Yes, I like that...... :D
Users browsing this forum: Majestic-12 [Bot] and 17 guests
