Condensation
Narrow gauge Nutter
Condensation
Postby Narrow gauge Nutter » Tue Jun 25, 2013 4:57 am
I am still working towards my APA version of greenhouse sidings.....
Having got the 1:32 greenhouse ends 3D printed (Tebee), I find I need to blur with condensation the view through the "glazing",
to disguise the fact that they are only 10-15mm deep.
Suggestions please.
Haven't decided on what material for the glazing yet, but want a realistic representation, not a uniform "obscure".
Lost in France and loving it!
Postby Artizen » Tue Jun 25, 2013 6:49 am
Postby Gerry Bullock » Tue Jun 25, 2013 3:50 pm
Hi David,
Suggest you try PVA applied in small quantities to back of glazing then dragged vertically with finger - better done before glazing is fitted.
I've just tried it with a clear plastic moulding used to hold an off shelf model and it looks reasonable.
I used Wickes PVA and the more expensive Anita's Tacky PVA.
Anita's gave better result as it seems to dry more opaquely.
However it will very much depend upon what glazing material you use as to how the effect develops.
Give it a try, it can be made very random with clear twixt the opaque streaks.
NotHarryPotter
Condensation
Postby NotHarryPotter » Tue Jun 25, 2013 7:55 pm
Indirect exposure to Zap a gap and other cyanoacrylate glues can give a frosted effect to clear windows.
I know this because I foolishly used CA to secure cab windows in an On30 loco, and the gas given off in that confined space turned the inner surface of the clear window material frosted. In this case it was not the effect I had hoped for!!
If you were to try this on your green houses, do some testing on some scrap material, and of course be careful with handling the stuff. It could be difficult to control effects, but if you need random frosting it might just work.
Geoff
Users browsing this forum: No registered users and 23 guests
