Emett inspired mallet "Pushmepullyou"
Mark Goodwin
Postby Mark Goodwin » Thu Jul 17, 2014 11:15 pm
Fellow Gn15 enthusiasts,
I have been thinking about doing a conversion from a Rivarossi DR C747 0-4-4-0 mallet into an Emett inspired mallet for the MG & FT LR. I managed to secure one on ebay a few days ago at a reasonable price. Pending its arrival from the USA to Canada, I have been researching the feasibility of such a venture. I will call the engine the "Pushemepullyou" from the two headed Llama from the Dr. Dolittle film. Once you see the cylinder arrangement you will understand why.
Here's what the Riviarossi model looks like:
http://www.ebay.com/itm/321455553040?_t ... EBIDX%3AIT
If I use the body of a basis for the new body, I think it will work. I will have to extend the buffer beam at the cab end for the new larger GN15 cab, but don't see this as being too much of a problem.
Well, here's hoping for a safe arrival via the postal services. More as the project develops. This is one that has been brewing for several months and has been delayed until a suitable donor loco could be sourced. This has now been achieved.............
Enjoy,
Kind regards,
Mark
Postby Willow Creek Traction » Fri Jul 18, 2014 1:37 am
Hey, alright. "Will watch this topic for replies" to keep track of how she goes.
Trevor Coburn
Postby Trevor Coburn » Fri Jul 18, 2014 5:45 am
Looks like a good buy Mark...it'll be interesting to see how this turns out...
Trevor.
Trevor
Postby rue_d_etropal » Fri Jul 18, 2014 9:01 am
I have one of those locos for possible Mallet conversion(reversing one bogie). The only odd thing with chassis is that the motor is in cab and drives to front bogie, by universal link. There is also a link back to rear bogie.
If I do my conversion I will have to reverse wheels as power is picked up on different sides for each bogie, and also lose the universal link between the bogies.
It is worth while looking round for these locos, as there seem to be quite a few on sale at the moment.
Being Rivarossi, everything is screwed together, making conversion a bit easier, and you can take things apart to test if they are suitable.
Mark Goodwin
Postby Mark Goodwin » Mon Oct 13, 2014 10:22 pm
Fellow GN 15 modellers,
Here is the progress so far on the project.
The rough sketch of what the engine will eventually look like:
This view shows the work so far on the chassis. The buffer beams have been extended to give some space for the cab and boiler. The Rivarossi mallet is quite a small engine. The body has been modified and is shown in position on the chassis. The buffer beams and cab side panel are "Smallbrook" castings from Mike Rayner. They are required to give a similar look as the rest of the MG &FT fleet.
This view shows the chassis without the body and gives a better view of the extensions for the buffer beams. The rear extension will be largely concealed by the cab and coal bunker..
I've decided to re-name the engine "Fenton" after the famous engineer, Roger Fenton. It has nothing to do with the following "Youtube" clip taken in Richmond park where a border colley has taken up deer herding, much to the alarm of his owner....................
http://www.youtube.com/watch?v=3GRSbr0EYYU
I just thought the name "Fenton" was funny........:)
Keep modelling and have fun,
Mark
Mark Goodwin
Postby Mark Goodwin » Mon Oct 13, 2014 10:34 pm
Correction, Roger Fenton was a photographer, not an engineer.
Postby rue_d_etropal » Mon Oct 13, 2014 11:08 pm
that gives me an idea, I wanted to modify my chassis into a more recognizable Mallet with cylinders both at front. As its old Rivarossi technology, everything unscrews, and I wanted to reverse one of the bogies. This would result in losing drive connection to that bogie, but I think it will still be powerful enough. Wheels would also have to reversed, as pickup is only on one side of each bogie.
Brack
Postby Brack » Tue Oct 14, 2014 5:01 pm
just move the cylinders, not the mechanism Simon. Put a styrene extension onto the front of the bogie and fix the cylinders to that.
Daniel Caso and myself are abusing a couple of these over on NGRM and he's worked out how to extend the axles for outside frames (his will be a 1/32 decauville mallet, and mine will be a 1/43.5 Bagnall Articulated like Monarch, so he'll need to make one bogie outside framed and reverse the cylinders on the other, whilst I need both outside framed, then cut the chassis and space the bogies further apart).
Postby rue_d_etropal » Tue Oct 14, 2014 9:33 pm
that is a possibility. It will be a while before I need to convert it, as I have so many projects in the pipeline. I will need to check which wheels can take the connecting rods to cylinders. I think I might have looked already, but it was earlier this year. The motor is also a challenge to fit in loco I plan which is the original Decauville Mallet in 1/35th scale.
Mark Goodwin
Postby Mark Goodwin » Fri Oct 31, 2014 1:57 am
Dear fellow GN15 modellers.
Here's the latest progress report.
Ignore the cab slope in the photo below. Some more work is required before final fitting, together with the tender. The bodywork is nearing completion, just some more details required.
Ooooohhh those close-ups can be soooooo cruel. I'm not re-rivetting the tanks. They were inspired by a recent colour photo of a Decauville tank loco recently published in the GN15 forum.
Blurred close-up for camera entusiasts.
Final note; the buffer beams, cab spectacle plate and other resin parts are Mike Rayner's Smallbrook studio "Emett" range.
That's all for now,
Mark
Mark Goodwin
Postby Mark Goodwin » Sat Nov 01, 2014 9:21 pm
Dear fellow GN15 modellers,
Work on the "Emettesque" mallet for the MG & FT has progressed with the fitting of the spectacle plate, coal bunker, chimney, tank filler caps and dome.
I decided that the way the cylinders are arranged, sort of opposite rather than in line, that the original name of "Pushmepullyou" should stand. I've put in an order for some nameplates with Narrow Planet (5mm high).
I'm waiting on an order for some detailing parts from the UK before completion. The next task will be the making of the back head and cab details, followed by the fitting of the roof.
Mark
Trevor Coburn
Postby Trevor Coburn » Sun Nov 02, 2014 8:29 am
Thats looking interesting Mark. I am looking forward to see it (her?) finished.
One of these days we'll have a grand meet of Gn15 stuff in BC (as most of my stock is there! )
Trev.
Trevor
Mark Goodwin
Postby Mark Goodwin » Tue Nov 04, 2014 12:57 am
Found the link to the Decauville locomotive that inspired the tank shape.
http://upload.wikimedia.org/wikipedia/c ... uville.JPG
The medication must be failing as the tanks had round bottoms and flat tops.
Ho hum, never mind.
Mark
Postby Nevadablue » Tue Nov 04, 2014 1:26 am
Your model is still beautiful. :)
Mark Goodwin
Postby Mark Goodwin » Tue Nov 04, 2014 3:45 am
Thanks Ken,
.....and I went to the hobbyshop today and brought some "Tichy Trains" 0.80 conical rivets..........and I've re-rivetted the front of the tanks to make them look even. I've added some detail to complete the full "Emettesque" treatment and I'll post some more pictures soon. I'm currently working on the back head detailing as, although these engines are the work of imagination, they must appear to be capable of movement like the real thing.
Kind regards,
Mark :shock: :D
Mark Goodwin
Postby Mark Goodwin » Tue Nov 04, 2014 4:09 am
Latest update
The front of the tanks have been improved and decorative detail.
Kind regards,
Mark
Postby Nevadablue » Tue Nov 04, 2014 5:31 pm
That is just cool! Nice work!
I really like the conical rivets. Many of the pressure vessels (around here) from long ago are riveted that way.
Steve Holland
Postby Steve Holland » Tue Nov 04, 2014 9:01 pm
That is going be an impressive model when it is finished.
There is something looking remarkably similar living at the Statfold Barn Railway just outside Tamworth. OK it is 2 foot gauge and not articulated but it is such an attractive machine.
I don't fancy making a model of the indirect drive and Brown's valve gear though!
Steve Holland
Mark Goodwin
Postby Mark Goodwin » Wed Nov 05, 2014 12:59 am
Hi Steve,
That one's a real beauty - the shade of green looks very much like the colour I plan to use for the "Pushmepullyou". It's called "greenskin" and is from the 'Army Painter' aerosol primer ranges. I'm keeping the original Rivarossi red wheels and chassis colours
The indirect drive Brown's valve gear would be difficult. I also like the smoke box door hinge and the shape of the water tanks. Thanks for your comments and sharing the photo.
Kind regards,
Mark
Mark Goodwin
Postby Mark Goodwin » Sun Nov 16, 2014 10:12 pm
Here are some photographs at the base coat/shading stage. Some washes, a little bit more details and a coat of varnish remain outstanding. I also have to complete the wood cladding on the boiler and fit nameplates.
You will notice that I have replaced the conical rivets at the front of the tanks.
Here's a close up showing the front tank detail and the new smoke box door from a Hornby A3 Gresley pacific. I like the profile for this larger type of engine. I have beefed up the hinges and replaced the door handle with a 7mm scale turned brass example.
Have fun and let's keep this wonderful site active.
Regards,
Mark
martin
Postby martin » Mon Nov 17, 2014 2:05 am
Lovely work as usual!
marter1229
Postby marter1229 » Mon Nov 17, 2014 3:05 am
That is a great looking little loco. thanks for sharing.
Terry
CDA, Idaho
Postby Nevadablue » Mon Nov 17, 2014 6:50 pm
What a wonderful little machine! Thanks for the updates! :D
Postby Simon Andrews » Tue Nov 18, 2014 1:16 pm
Lovely work. The loco is full of character.
Chris18
Interests: G and Gn15.
Postby Chris18 » Wed Nov 19, 2014 8:49 pm
Wonderful loco ! I really like it.
Users browsing this forum: Google [Bot] and 21 guests
