Graham Farish N Gauge Track
Posted: Tue Aug 09, 2016 4:10 pm
by Montignac
Hello there,
Did anyone use the Graham Farish N Gauge Track to build a Gnine layout ?
Thanks for all your answers.
Re: Graham Farish N Gauge Track
Posted: Wed Aug 10, 2016 12:04 pm
I would hope that you could find smaller radius track. The brand new Minitrains stuff looks good, but I use Kato as it has 6" radius.
Posted: Wed Aug 10, 2016 1:19 pm
by Montignac
Posted: Sat Aug 13, 2016 1:39 pm
by Montignac
docnjoj wrote:I would hope that you could find smaller radius track. The brand new Minitrains stuff looks good, but I use Kato as it has 6" radius.
These two video show the new Minitrains track system (which is too expensive for me :( )
MiniTrains track - Run-test forward
MiniTrains track - Run-test backwards
Posted: Sat Aug 13, 2016 1:51 pm
by Montignac
Anyway, I bought one Graham Farish Straight Track (174mm) just for a test:
What's the best solution for Gnine track ? All your answers are welcome.
Posted: Sat Aug 13, 2016 2:22 pm
Although the sleepers look a little small (but it's your line, so do as you wish) I think the '2 sleepers removed' looks acceptably similar to very lightly laid lines in larger gauges. As the rail itself is large for the gauge it represents it wouldn't need a lot of support.
Here's a shot from the 10 1/4" gauge Rudyard Lake Railway, the run round right at the end of the line. And this takes locos that weight up to one 1 ton.
Posted: Sat Aug 13, 2016 2:35 pm
by Montignac
Thanks Chris for your reply and the photo. You're right, my sleepers are a little bit small. As you said, it's my layout, so I do what I want...or what I can ! :oops: .
Posted: Sat Aug 13, 2016 2:58 pm
Although I am currently using wood sleepers for my 7 1/4" gauge line around garden/paddock to carry manure, garden produce and such I will use recycled plastic in the paddock as I am going to try laying in (wet) grass. These will come from
http://www.pnp-railways.co.uk/products/7-gauge-sleeper/
And are
Dimensions: (L) 353mm x (W) 50mm x (H) 25mm
And are thus quite small.
Posted: Sun Aug 14, 2016 1:55 pm
Wow injection moulded ties! I wonder about using Trex decking?
Posted: Sun Aug 14, 2016 1:57 pm
Montignac wrote:Anyway, I bought one Graham Farish Straight Track (174mm) just for a test:
Those look good to me too! I am waiting to see Minitrains track pricing if it ever gets to the US.
Posted: Sun Aug 14, 2016 2:07 pm
by Montignac
docnjoj wrote:I am waiting to see Minitrains track pricing if it ever gets to the US.
Try this link:
http://www.minitrains.eu/sources/track-usd-8-2016.pdf
Posted: Sun Aug 14, 2016 2:28 pm
Hi Doc,
I don't know about Trex specifically but there are plenty of miniature railway clubs here in the UK that now use recycled plastic for sleepers.
Posted: Fri Sep 30, 2016 6:13 pm
Whoops just saw this Chris. Trex or any plastic composite gotta be more enviro friendly than creosote ties.
Posted: Thu Oct 13, 2016 10:14 am
by lesmond
I'm using Kato Unitrack for a project to be revealed a bit later.
It looks nothing like "proper" ng track as the sleepers are far too small and close together (I know a few people who's eyes are like that too - usually their mother is also their sister) but for this job it doesn't matter :D
Posted: Fri Oct 14, 2016 1:14 pm
The trick with Unitrack is to use the tram type so no sleepers show at all. It is embedded and you use concrete or cobbles around it.
Then it looks OK.
Posted: Sat Oct 15, 2016 9:47 am
It is just a pity there are no ponts with inlay, apart from the double junction. Tomix do a set to do infill, which came out before the inlaid track, but it cheats a bit, especially with the point.
Posted: Sat Oct 15, 2016 2:05 pm
I bought some of yours, Simon, for GN15 and they seem fine, but of course then I decided to do G9. I think your solution is the best and I got one in GN15 to work without any movement, just the proper gaps where the wheels go through. Of course mine are deadrail, so no pesky electrics to worry about. Mine are for a reverse loop so the trains only go one way around. Obviously if you want a choice than you have to have the points move.
Posted: Sat Oct 15, 2016 4:32 pm
by lesmond
I didn't know of the tram type - thanks for that. That will solve a problem for (yet another) wee project.
