rivet counters unite!
southpier
Postby southpier » Tue Oct 02, 2018 1:30 am
NotHarryPotter
Re: rivet counters unite!
Postby NotHarryPotter » Thu Oct 18, 2018 6:44 am
Thanks for posting. What material is used to represent the explosions? I can see it is lit be LED, but is is cotton wool?
Geoff
Postby Thorness » Thu Oct 18, 2018 10:21 pm
From the Blog (under Burning Wrecks)::
Poly-Fil® is used for the smoke. Since the Poly-Fil is pretty light and flimsy I've bent a wire to use as an armature. It will be inserted into a small hole,
It looks like pillow stuffing to me.
NotHarryPotter
Postby NotHarryPotter » Fri Oct 19, 2018 7:07 am
Thanks Don,
Geoff
Geoff
