Locolines is back
crackingjob
Interests: 16mm Gn15 garden railways
Locolines is back
Postby crackingjob » Tue Feb 26, 2013 10:07 pm
I see over on the gardenrails site that Roy of Locolines fame is back, though has to call it Rail-Road as there seems to be lots of companies called Locolines
he is still doing Ivor the Engine
http://royfitzsimmonds.wix.com/rail-roadmodels
Crackingjob
Railways of Austerity and Thrift
rjt
Interests: 16mm -NG & garden railwayscales
Postby rjt » Wed Feb 27, 2013 1:52 pm
problem with the link, or is it my hardware? seems there's something wrong with the site. What is the link for the garden rail site too?
Rob (Oxon, UK)
Rob (but Gnever 'Bob')
Postby rue_d_etropal » Thu Feb 28, 2013 5:19 pm
loads OK, but I think it was a bit slow first time.
Interesting point about being only officially licensed Ivor model.
Personally I prefer plastic to card, and would use card version as a template.
There was a range many years ago which came of sticky-back paper(basically an A4 sized label), so all you had to do was cut out stick to plastic, then cut out plastic shape and removing paper. I used to print out some door/window designs this way before I discovered mashed paper.
crackingjob
Postby crackingjob » Fri Mar 01, 2013 7:03 pm
