semaphore signals?
DuffieldBank
semaphore signals?
Postby DuffieldBank » Wed Jan 27, 2016 10:16 pm
Hello chaps. Would anyone have more information on this type of miniature semaphore found at the Ashmanaugh Light Railway? Some rough dimensions and construction notes would be greatly appreciated.
ashmanhaugh semaphore signal post.JPG (179.92 KiB) Viewed 3378 times
Re: semaphore signals?
Postby Nevadablue » Thu Jan 28, 2016 12:49 am
I don't have info, but I like it! Photo saved, thanks!
Postby chris stockdale » Thu Jan 28, 2016 6:51 am
DuffieldBank
Postby DuffieldBank » Thu Jan 28, 2016 5:33 pm
I've already done so Stockers!
=P
Postby chris stockdale » Thu Jan 28, 2016 6:11 pm
Good oh!
Do let us know what you learn please.
Steve Holland
Postby Steve Holland » Thu Jan 28, 2016 7:55 pm
From an S & T engineer's viewpoint is it upper or lower quadrant, or (as there does not appear to be any operating mechanism) a fixed distant?
Before anyone asks - S & T = Signals and Telecommunications, or Sick and Tired (after a rough 12 hour commissioning equipment trackside in the winter), or Sabotage and Terrorism :shock: It all depends on your point of view.
Steve Holland
nonsuch
Postby nonsuch » Fri Jan 29, 2016 2:39 pm
Steve
As it is a fixed distant signal - yellow and black with a fishtail - it doesn't need any operating mechanism, and the quadrant type is thus irrelevant.
Neil B, sometime railway signal engineer
Neil B
Steve Holland
Postby Steve Holland » Fri Jan 29, 2016 6:15 pm
As a full time working, IRSE licensed, signal engineer the shape and colouring of a distant signal arm is always the same, fixed or not. That is yellow with a black band and fish-tailed (after 1923; prior to that they were red). The shape of course is a visual identifier to differentiate it from a home (stop) signal. The rear face has always been white with a black band.
The signal in the photo has an unfortunate feature in that if the bolt fixing the arm to the post should become loose, the arm will potentially drop to a clear position - a 'wrong side' failure as it is unsafe. All lower quadrant signals had a large heavy spectacle casting that would return the arm to danger if any part of the mechanism failed - this one does not. Of course there could be a stop to prevent the arm drooping on the back of the arm that cannot be seen in the photo. I hope so, especially if the rest of the signals on the line are lower quadrant.
The last time I had anything to do with a mechanical distant was at Radyr, for the Radyr - Pontypridd resignalling when one was installed underneath the Up starter and motor worked from the new solid state interlocking. Shame we recovered it on a later stage of the job as I think it was unique even then and nothing like it has been done since.
Steve Holland
DuffieldBank
Postby DuffieldBank » Sat Feb 20, 2016 1:39 pm
I've managed to draw up a GWR finial for when I actually start building these. I will 3D print them at 1/3 scale size for my backyard line.
GWR semaphore finial test print.png (56.77 KiB) Viewed 3119 times
