Indonesian Railcars
DCRFAN 3
Indonesian Railcars
Postby DCRFAN 3 » Mon Jun 18, 2018 12:48 pm
Heck this is just about prototype Gn15 https://www.facebook.com/ilham.rasoki/v ... 294280456/
And another https://youtu.be/8hsyLQTiTjg
I'm sure they are using 1:1 scale Black Beatle or Tensodo motor bogies :P :P
DCRFAN 3
Re: Indonesian Railcars
Postby DCRFAN 3 » Tue Jun 19, 2018 7:42 am
I've been doing some research, the railway is at Lebong Tandai and is now 600mm gauge but was originally 500mm. Once had a vast range of locomotives including some very usual Simplex.
The current rolling stock are known at Molek = Motor Lori Ekspres.
Postby tebee » Sun Jun 24, 2018 12:32 pm
If it's the line I think it is it was originally overhead electric with little O&K locos.
I may have some photos somewhere.
Postby rue_d_etropal » Mon Jun 25, 2018 5:57 pm
Doubt if it was originally 50cm gauge, so googled it, and found this
http://www.internationalsteam.co.uk/tales/indonesiatales01.htm
Turn out the mine section was 50cm but the rest has alwaysbeen 60cm gauge.
I think if you exhibied a layout with these railcars(??), people would not believe they existed. Sometimes fact is stranger than fiction.
