A Hair Raising Ride?
Postby Gerry Bullock » Fri Oct 18, 2013 3:59 pm
Gnot Minimum Gauge, a railway none the less. :shock:
http://www.dailymail.co.uk/news/article ... sight.html
Postby rue_d_etropal » Fri Oct 18, 2013 6:15 pm
I would say that is almost a 'lift' as it is pulled by a cable and doesn't drive itself. Similar to cable operated wagon lifts, which is what I assume it was originally. No geared centre rail I notice.Hopefully it has suitable failsafe gear.
RoGNer
Postby RoGNer » Fri Oct 18, 2013 6:44 pm
:shock: eeeekk!
Fantastic!
Roger
Feeling icky!
Postby Adrian » Sat Oct 19, 2013 1:03 am
G'day
And now it has been drawn to the attention of 'ealth & safety how long will it remain as is and not 'nannyed' down ????
crackingjob
Interests: 16mm Gn15 garden railways
Postby crackingjob » Thu Nov 07, 2013 11:11 pm
Naaaa... thats nothing.
This has been posted on 7/8ths.info by 'ashe' and I thought its one for us to see also
http://www.nrc.nl/inbeeld/2013/11/05/el ... kabelbaan/
Railways of Austerity and Thrift
Postby Gerry Bullock » Fri Nov 08, 2013 2:13 pm
Hardly a railway! :roll:
