Clarabel has a new (laser-cut) dress
DuffieldBank
Postby DuffieldBank » Wed Aug 30, 2017 1:46 pm
Laser cut and coming soon...
Gn15 coach on clarabel.jpg (205.32 KiB) Viewed 4876 times
Re: Clarabel has a new (laser-cut) dress
Postby docnjoj » Thu Aug 31, 2017 12:06 pm
Your coach and my Tom Yorke one I can actually make a passenger train! Looking forward to it.
DuffieldBank
Postby DuffieldBank » Sat Sep 02, 2017 7:30 pm
A few test cuts on a dreary Saturday...
coach test 1.jpg (276.27 KiB) Viewed 4788 times
coach test 2.jpg (159.66 KiB) Viewed 4788 times
coach test 3.jpg (226.07 KiB) Viewed 4788 times
DuffieldBank
Postby DuffieldBank » Sat Sep 02, 2017 7:32 pm
QUESTION: Would everyone like to keep the buffers that are moulded into the chassis or is it ok to remove them?
Thanks
DB
Postby lesmond » Sat Sep 02, 2017 8:38 pm
That is lovely :)
I'd prefer the chassis with no buffers if possible.
DuffieldBank
Postby DuffieldBank » Sat Sep 02, 2017 10:17 pm
lesmond wrote:That is lovely :)
Agreed. There's really no way they would work properly either.
Cheers.
DuffieldBank
Postby DuffieldBank » Sat Sep 02, 2017 10:22 pm
Here's the latest incarnation. I'll have to stop now as there are no lights in the shed. A giant laser cutter, but no lights. LOL
I'm very pleased that the sash for the drop down window in the door came out so cleanly, even though it is only .050" across. I also changed the end, as I felt having only 4 recessed sections looked "wrong"; 5 is much better.
The final kit will be produced using different thickness materials so as to hide all of the corner notching. This was done with what I had to hand.
coach 1.jpg (83.2 KiB) Viewed 4779 times
coach 2.jpg (88.69 KiB) Viewed 4779 times
coach 3.jpg (96.86 KiB) Viewed 4779 times
coach 4.jpg (74.94 KiB) Viewed 4779 times
DB
Postby lesmond » Sun Sep 03, 2017 9:59 am
The bother you are going to save me with this is immense :)
Postby docnjoj » Sun Sep 03, 2017 1:16 pm
Will the chassis come with the kit? I don't know what a "Clarabel" is?
Colonist don't you know!
OK got it! It is an HO passenger car from the Thomas series. Probably difficult to source in the US. Are there any alternatives?
DuffieldBank
Postby DuffieldBank » Sun Sep 03, 2017 5:28 pm
docnjoj wrote:Will the chassis come with the kit? I don't know what a "Clarabel" is?
Not difficult at all. I believe they are still freely available on Ebay and perhaps even retail. That is where I found mine, and I am currently a "colonist" as well. (Shhh...)
DB
DuffieldBank
Postby DuffieldBank » Sun Sep 03, 2017 5:29 pm
Latest update: Assembled inner box structure in situ on chassis. I need to trim off those pesky buffers!
DB
assembled coach test.jpg (193.4 KiB) Viewed 4734 times
DuffieldBank
Postby DuffieldBank » Sun Sep 03, 2017 5:30 pm
lesmond wrote:The bother you are going to save me with this is immense :)
:mrgreen:
Postby docnjoj » Sun Sep 03, 2017 5:32 pm
The Peco on30 chassis is also readily available. I have one for the Tom York resin car. Dapols can also be had, but from Britain.
DuffieldBank
Postby DuffieldBank » Mon Sep 04, 2017 1:44 pm
docnjoj wrote:The Peco on30 chassis is also readily available. I have one for the Tom York resin car. Dapols can also be had, but from Britain.
Do you mean this one?
http://tinyurl.com/y9nlzahd
I'll have to look into that, as I did not know it even existed!
Thanks for pointing it out.
DB
DuffieldBank
Postby DuffieldBank » Mon Sep 04, 2017 7:48 pm
Almost ready for public consumption. I will post a link to my Shopify store shortly.
DB
coach assembly 4.jpg (273.22 KiB) Viewed 4677 times
coach assembly 3.jpg (275.74 KiB) Viewed 4677 times
coach assembly 2.jpg (280.07 KiB) Viewed 4677 times
coach assembly 1.jpg (261.47 KiB) Viewed 4677 times
Postby docnjoj » Tue Sep 05, 2017 12:54 pm
This is wonderful as there are few to none similar models. Yes the Peco is correct. It has a shorter wheelbase compared to Clarabel, but cheaper by far.
DuffieldBank
Postby DuffieldBank » Tue Sep 05, 2017 8:42 pm
Quick update: Pricing will be less than 20USD.
DB
Postby KEG » Wed Sep 06, 2017 10:25 am
How about some dimensions of the box. How many passenger will it hold?
2 compartements should be enough room for 8 seated passengers.
Two in each compartement will have no window to look out.
DuffieldBank
Postby DuffieldBank » Wed Sep 06, 2017 1:44 pm
KEG wrote:How about some dimensions of the box. How many passenger will it hold?
Coach is approx. 8' 6" by 42" wide. I am still working out the kinks for the interior arrangement. I can easily add additional windows, so no worries.
DB
Postby KEG » Wed Sep 06, 2017 4:27 pm
That scales out to approx. 108 by 48 mm for the model.
Figures sitting oppsite need approx 70 mm, so the coach is too short
for 2 populated compartement.
DuffieldBank
Postby DuffieldBank » Wed Sep 06, 2017 7:40 pm
Since I am using an existing chassis, I am somewhat constrained in altering the design. I figured on 2 seated with their luggage.
DB
DuffieldBank
Gn15 coach now available for purchase!
Postby DuffieldBank » Fri Sep 15, 2017 9:27 pm
NOW ON SALE
Here's a first-of-its-kind laser cut kit for a typical minimal coach. Designed to fit a Bachmann HO scale Annie/Clarabel coach chassis from the Thomas The Tank Engine range (not included), this wonderful coach will afford your scale figures a comfortable ride in style as they trundle around the layout.
The kit consists of laser cut Taskboard and birch plywood panels, which utilize a tab and slot assembly method for a foolproof build. A laser cut interior with floor and seating, plus a roof and couplings are also included. All you provide is the glue and paint colours of your choice.
Take advantage of our introductory pricing while it lasts! $19.95 USD per car.
Link to online store: https://theoriginaltwofoot.wixsite.com/mygn15
kit 4.jpg (202.98 KiB) Viewed 4480 times
kit 5.jpg (184.94 KiB) Viewed 4480 times
kit 6.jpg (292.65 KiB) Viewed 4480 times
kit 3.jpg (125.69 KiB) Viewed 4480 times
Postby More_Cats_Than_Sense » Sat Sep 16, 2017 10:00 am
What sort of postage cost is going to be on these kits to UK/Europe?
Postby docnjoj » Sat Sep 16, 2017 7:41 pm
I just ordered one!
DuffieldBank
Postby DuffieldBank » Sat Sep 16, 2017 8:15 pm
More_Cats_Than_Sense wrote:What sort of postage cost is going to be on these kits to UK/Europe?
I apologise for the excessive shipping costs calculated by the Shopify store for my UK and EU customers. Please message me directly, and I will send a PayPal invoice which will utilise a much cheaper shipping option.
Thank you for your patience!
DB
