Save 10% at my Gn15/G9 store. OFFER EXTENDED!
DuffieldBank
Postby DuffieldBank » Sun Oct 22, 2017 8:24 pm
NOTICE: To celebrate my new Gn15 kits, every order placed between this moment and midnight (EDT) on Monday, October 23 will receive a 10% discount!
Use the code "Save10" at checkout.
https://theoriginaltwofoot.wixsite.com/mygn15
Re: Save 10% at my Gn15/G9 store. Limited offer!
Postby KEG » Tue Oct 24, 2017 9:24 am
Discount always sounds good. But I would love to know the model modensions of these offers.
Even more, I´d like to see them built and photographed along with Gn15 models from other makers plus some scale figures, to get an idea of the actual model dimensions.
The above samples seem to be extremely narrow and have vertical boards missing at the the sides.
Postby chris stockdale » Tue Oct 24, 2017 3:59 pm
The website doesn't run super smoothly from my iPad, but well enough to see that the scale is given as 1/24 with dimensions of the original prototype.
DuffieldBank
Postby DuffieldBank » Wed Oct 25, 2017 3:39 am
KEG wrote:Discount always sounds good. But I would love to know the model modensions of these offers.
Hi Juergen. For example, the guards van is as follows: a scale 7'9'L x 3'W x 5'H less running gear.
DB
Postby KEG » Thu Oct 26, 2017 7:52 am
Thanks for the picture with the Carlo Spirito figure. The goods wagon indeed looks tiny.
78 mm long, 38mm wide, 62mm high (plus chassis. Almost HO dimensions.
Too small for my Gn15 purposes.
Have a look at Smallbrook Studios Gn15 offerings. Locos are 45 mm wide, the Decauville inspection car for four passengers is 50mm wide. http://www.smallbrookstudio.co.uk/products-new/4569521214/gn15-decauville-inspection-coach/11151500
Hope to see some more assembled laser models.
DuffieldBank
Re: Save 10% at my Gn15/G9 store. OFFER EXTENDED!
Postby DuffieldBank » Fri Oct 27, 2017 8:54 pm
OFFER EXTENDED
To celebrate the upgrade of all my kits to now include proper 3 hole disc or spoked wheels, underframe with pedestals, plus bearing inserts for the needlepoint axles (to allow for excellent rolling capabilities), I have extended the discount period. Please take advantage of this early and often. ;)
DB
Postby docnjoj » Sat Oct 28, 2017 11:07 am
Hi Chris. Is there any way that we can order the new wheels and underframe parts for models we have already purchased. I would love to pay for them to make assembly easier and not have to order and destroy Thomas cars.
Thanks in advance.
DuffieldBank
Postby DuffieldBank » Sat Oct 28, 2017 1:47 pm
docnjoj wrote:Hi Chris. Is there any way that we can order the new wheels and underframe parts for models we have already purchased. I would love to pay for them to make assembly easier and not have to order and destroy Thomas cars.
Thanks in advance.
Yes indeed. I will be sending out an email to all early purchasers to allow them to do so.
thanks
DB
Postby docnjoj » Fri Nov 10, 2017 6:54 pm
Hey Chris. Is there a way to make the doors open with real hinges? I know to cut on the lines, but do you have a specific plan?
DuffieldBank
Postby DuffieldBank » Sat Nov 11, 2017 4:24 am
docnjoj wrote:Hey Chris. Is there a way to make the doors open with real hinges? I know to cut on the lines, but do you have a specific plan?
I can easily modify the drawings to "cut" instead of "scribe" the door lines. The hinges themselves would be the tricky part.
DB
Postby KEG » Sat Nov 11, 2017 8:25 am
OZARK offers various suitable hinges. # 4073 operates and can be modified to fit the purpose:
(Note, the hinges in this case are used for the tool box of a 7 / 8ths scale model
It houses the Deltang RC receiver)
Problem with the boxcar design is, the hinges are planned to get fixed between boards. They should be mounted
on a board to be prototypicallly.
Postby docnjoj » Sat Nov 11, 2017 3:14 pm
Thanks Chris and Juergen
I have been looking at doll house hinges and found some around 1/4 inch (6mm) square. I'll check with Ozark too.
