(M) Acrylic Paints
(M) Acrylic Paints
Postby Gerry Bullock » Fri Feb 24, 2012 7:37 am
A fellow Club member uses this range of paints.
Much cheaper than the Games Workshop or Vallejo range.
http://www.polyvine.com/shop/show/craft ... enamels/26
Have now found that Homebase stock the range of Craft paints, 100ml for £4.19 - likely to go off in those quantities before all is used.
MrPlantpot
Postby MrPlantpot » Thu Mar 08, 2012 9:45 am
Thank you Gerry, I've seen this website before, but had forgotten about it.
They do that paint in 40ml jars, but even that is nearly 3 times the size you get Humbrol in.
They also do "Acrylic Enamel" which just doesn't sound right to me. :?
There is a store locator button towards the bottom of their menu... there are 3 or 4 shops near me that stock it, so I may take a look.
Cheers.
My Mum calls me Steve.
Users browsing this forum: Google [Bot] and 1 guest
