shapeways
Dawdawes
Interests: Fancy modelling bigger in smaller spaces
shapeways
Postby Dawdawes » Sat May 04, 2013 5:29 pm
Hi all was not sure if anybody had looked at shapeways lately, there's quit a lot of Gn15 items on there all on a par with Pepper 7
Cheers Dave
Postby rue_d_etropal » Sat May 04, 2013 7:24 pm
there have been a number of threads. Tom is also sometimes here on the forum.
Narrow gauge Nutter
Postby Narrow gauge Nutter » Sat May 04, 2013 7:50 pm
I hope Tom doesn't mind, but spoke to him today and there are various things in design at the moment including G gauge bogies and drive units in 16.5mm.
Keep watching :lol:
Lost in France and loving it!
Postby tebee » Sun May 05, 2013 1:47 pm
Tom never minds publicity !
The prototype for the motor bogie is now available http://www.shapeways.com/model/881479/1 ... block.html
It's designed to be a better running and more robust SPUD replacment.
Everything seems to fit and go together OK but I've not had a chance to complete mine as I discovered I need a broatch to enlarge the holes in the worms slightly so they fit on the lay shaft.
Outside jobs have prevented from locating and ordering as set of cutting broaches but I do intend to get round to it in the next couple of weeks, then I can finish this off.
Postby KEG » Mon May 06, 2013 2:08 pm
Well, there are a few Gn15 models offered at Shapeways. But you don´t see them assembled or painted very often in here.
http://www.shapeways.com/search?q=Gn15&s=0
I would not mind seeing the Gn15 Decauville built an detailed by someone. Saw, smelled and touched a real one in Frankfurt yesterday.
Including buffers, it is only 400 cm long. It celebrated its 101th birthday and is still running fine. After spending the most of its live in Greece.
jameswaterfield
Postby jameswaterfield » Mon May 06, 2013 9:44 pm
Nice picture Juergen
Is it the Volos engine and where is it now?
Thanks
James
James Waterfield
Postby KEG » Tue May 07, 2013 5:50 am
Yes, it is the the engine "DIMITRIAS which used to run from Volos to Miles. , built 1912. It belongs to the Feldbahnmuseum in Frankfurt now.
Brack
Postby Brack » Thu May 09, 2013 4:56 pm
Ah, but it isn't THE Volos enigne. The frankfurt one is an early type 3 I think. works No. 509 is the black one in Volos at the brickworks and it is mostly a type 1 (its been a bit kitbashed), so a bit smaller (about 2700mm in length).
Postby KEG » Fri May 10, 2013 11:44 am
The Decauville in Frankfurt is No. 648 / 1912.
They mention in their catologue, it was delivered with a sister loco
named ARGO to the Thessalian Railway.
It is possibly this one http://commons.wikimedia.org/wiki/File:Volos_Decauville_locomotive.jpg
