Gem-u-Nine
Postby Gerry Bullock » Sat Mar 03, 2012 9:28 am
Glen A wrote:But the best one I thought of was a little speaker mounted under the floor which played the sounds of the grandfather clock chiming.
Consider it done Glen. 8)
Fellow Club member who's an electronics wizz-kid already has recordable chips on order to support Guy's FIzz-Bang upgrade, some come with proximity sensors though we don't know how sensitive the sensor is.
Could even record my own Grandfather (Clock) for the shop. :D
Another clock
Postby Gerry Bullock » Wed Mar 07, 2012 4:34 pm
I thought that the desk in the shop would be enhanced by a French Clock albeit the painting in this size of photo looks pretty poor. :oops:
It is but 16mm tall.
MrPlantpot
Postby MrPlantpot » Wed Mar 07, 2012 9:10 pm
Hi Gerry,
That's a nice little clock.... but it's 25 minutes ahead of the long case in the back. :?
Also, I've a feeling that a 5'6" clock may be called a Grandmother. I know more about horticulture than horology, and precious little about that. :shock: Somebody will enlighten us.
So, where's it gunna go? Mantlepiece, or desk?
My Mum calls me Steve.
Postby Gerry Bullock » Thu Mar 08, 2012 10:15 am
MrPlantpot wrote:Hi Gerry,
Right here Steve:
You're correct it would be a Grandmother however I guess Petite Properties, from whence it came, considered retailing it as a Grandmother might have reduced its appeal. :roll:
Having more than 10 clocks dotted around our bungalow not all show the same time, primarily because I don't wind them all. :lol:
Perhaps the French Clock is just a showpiece, might be right in 25 minutes if they've remembered to wind the Grandmother. :wink:
Postby Gerry Bullock » Fri Mar 09, 2012 3:33 pm
Here's the upper floor nearing completion:
Difficult to see through the windows, if you peer hard enough this is what is inside:
Postby Gerry Bullock » Sun Sep 14, 2014 8:21 pm
I'm afraid that this building is Gnever going to find a home on the proposed layout as my sight has deteriorated to the extent that bad eye is distorting vision of good eye when working close-up :cry:
Anyone in UK interested in building - cannot be posted!
Postby Gerry Bullock » Wed Oct 01, 2014 4:09 pm
Gone to Doll's House world.
Postby Nevadablue » Thu Oct 02, 2014 1:13 am
Wow Gerry, that's a shame about the eye. Isn't there any way to correct the 'bad' one or cover it while working? Sight is such a precious thing. I hope things work out for you.
