2015 challenge
2015 challenge
Postby rue_d_etropal » Sat Dec 20, 2014 10:21 am
Enough discussion, time to set the challenge
2015 is the centenary of the opening of the 15in gauge Ravenglass and Eskdale Railway, well more like the conversion from to 15in from 3ft gauge.
It seems a good opportunity to tie this in with the relaunched forum, as I would hope there is some interest and publicity in model railway press.
Here is my proposal then.
size to be 19 by 15 in(1915 connection) , no extra for fiddle stick etc(the extra 4in on base should be enough), and that is outside dimensions including backscene. This means it could be placed inside a piece of 15in gauge track as part of exhibition.
Gn15
Working , not static
At least one operational point or turntable (suggestion from Martin, I am not trying to promote my 3D printed wagon turntables, really... :lol: ).
Aim would be to show as many off as possible in one place, but could include video of those too far away. Also would aim to get something in model railway magazines, September issues as they tie in with the centenary event.
Back in 2006/7 Michael launched a challenge to build something in paper, and my effort by pure chance happens to be 19in by 15in. Luckily I still have photos, which I have put on one of my own webpages for speed and simplicity .
http://www.rue-d-etropal.com/Model-pics/Chateau-d-etropal/chateau-d-etropal-pix.htm
Hopefully this should show you can fit in quite a lot ,but it does not have to be continuous run, it can be like Carl's original module.
martin
Re: 2015 challenge
Postby martin » Sat Dec 20, 2014 12:51 pm
I'm in!
Re: 2015 challenge
Postby rue_d_etropal » Sat Dec 20, 2014 5:14 pm
I have tried to contact the Ravenglass & Eskdale Railway about their centenary event, but given the time of year had no reply yet.
As I mentioned before I actually already have a mini layout which is 19in by 15in, from the paper challenge. I plan to get that cleaned up, and build another layout, this time hope to use 3D printed track if it works OK. I had done some very rough 10cm radius sections, but plan to design new one based on what I have learned over past year. I will draw inspiration from some of the mini layouts that have featured here.
I am currently also getting my rail mounted wheelie big operational again, and started on some small wagons based on Underground Ernie coach bogies, as they are very free running.
Hopefully someone will do something Ratty inspired.
cjwalas
Re: 2015 challenge
Postby cjwalas » Sat Dec 20, 2014 11:53 pm
I think I'm in as well. But don't expect anything too realistic from me... sorry. Is there a timeframe established?
It seems I can only get onto the Gnatterbox for about three hours a day for some reason. anon know what that's about?
Re: 2015 challenge
Postby Nevadablue » Sun Dec 21, 2014 12:30 am
I'll try to do something. I doubt that anything I make would be 'magazine quality', but the size limit fits (sort of) into my diorama module size. I have settled on 16"x 24" to make it fit standard US lumber size, but I can make one smaller and fit it into the overall layout.
Re: 2015 challenge
Postby rue_d_etropal » Sun Dec 21, 2014 12:33 am
The R&E centenary event is at end of August as far as I can tell. That sounds like a good target date, but I might try contacting magazines to see if they are planning anything.
martin
Re: 2015 challenge
Postby martin » Sun Dec 21, 2014 7:12 pm
cjwalas wrote:I think I'm in as well. But don't expect anything too realistic from me... sorry. Is there a timeframe established?
I don't think i'll be doing anything too realistic either. if I had the time I would, as I don't ill be taking the easy option! :D
martin
Re: 2015 challenge
Postby martin » Mon Dec 22, 2014 12:29 am
Nevadablue wrote:I'll try to do something. I doubt that anything I make would be 'magazine quality',
Making something "Magazine Quality" isn't really what Gnatterbox Challenges are about... it's about getting people modelling, showing what can be done with minimum gauge and minimum space. Besides your modelling is great!
Re: 2015 challenge
Postby Nevadablue » Mon Dec 22, 2014 12:38 am
Thanks Martin, I guess you are right about the purpose of the challenge. I just can't see my work in the same class as the other stuff I see here and elsewhere. I suppose it really doesn't matter. If I have fun that's great and if someone else enjoys it that's even better.
Chris18
Interests: G and Gn15.
Re: 2015 challenge
Postby Chris18 » Mon Dec 22, 2014 11:16 am
Nevadablue wrote:Thanks Martin, I guess you are right about the purpose of the challenge. I just can't see my work in the same class as the other stuff I see here and elsewhere. I suppose it really doesn't matter. If I have fun that's great and if someone else enjoys it that's even better. :)
You're absolutely right.
Chris18
Re: 2015 challenge
Postby Chris18 » Mon Dec 22, 2014 12:51 pm
One question about this challenge: Am I right ?
Geeky Gecko
Interests: modelling in card
Re: 2015 challenge
Postby Geeky Gecko » Mon Dec 22, 2014 3:40 pm
http://imageshack.com/a/img909/4450/w0idFN.jpg
Is there a height limit?
If I have a go at this challenge, I hope nobody will mind if I use existing stock made for 1:25. After all, I'll have to make a rail bender and probably construct points and/or a turntable. Each will be a first for me.
Stefan
Re: 2015 challenge
Postby rue_d_etropal » Mon Dec 22, 2014 4:28 pm
I suggest no height limit, it makes it more fun , as some of the most unusual/fun mini layouts have been tall .
Chris18
Re: 2015 challenge
Postby Chris18 » Mon Dec 22, 2014 5:02 pm
OK. I was wrong. :lol:
Re: 2015 challenge
Postby Simon » Mon Dec 22, 2014 8:01 pm
Following in the best traditions of Sir Jack (ignoring what other people say), I'm in, but am going to massage the rules slightly.... I believe that the idea of having a mandatory turnout as so that there was some operational interest to the layout rather than just round and round. Thus, I've come up with a design* that does have a fair bit of operational interest and no round-roundy but has no turnouts - it has a couple of turntables instead. Hope this doesn't cause too much upset?
* second go after the ban on fiddle sticks meant going back to the drawing board.....will save that one for another day.
Re: 2015 challenge
Postby rue_d_etropal » Mon Dec 22, 2014 8:18 pm
that's why I included turntables, but maybe some might think I meant both . Just checked, I did say 'or', and that is the 'inclusive or', so either,or both, but at least one. Think that makes sense :roll:
Re: 2015 challenge
Postby Gerry Bullock » Mon Dec 22, 2014 8:22 pm
Hi Simon, where does it say mandatory turnout?
"size to be 19 by 15 in(1915 connection) , no extra for fiddle stick etc(the extra 4in on base should be enough), and that is outside dimensions including backscene. This means it could be placed inside a piece of 15in gauge track as part of exhibition.
Gn15
At least one operational point or turntable (suggestion from Martin, I am not trying to promote my 3D printed wagon turntables, really... :lol: )."
Clearly states 'or' so you are Gnot 'massaging the rules'.
By the way when I ran similar defined comps for my Rail Club any contravention of aforesaid rules resulted in disqualification.
Previous challenges on Gnatterbox have been voted on by the membership therefore rule compliance will undoubtably be noted in the comments posted prior to any vote on this Challenge. Assuming that is the intention of Simon D.
Re: 2015 challenge
Postby rue_d_etropal » Mon Dec 22, 2014 8:31 pm
Gerry, I think I agree. Just noticed I think you mean the other Simon. I will have to modify my signiature, so that I am officially Simon D.(and I do remember the DJ with name that sounded the same 8) )
I would have liked to have put it out to membership, but feared it would drag on, and there is not that much time, I think it is waking people up though.
I was also trying to get some publicity for Gn15, and that can take time to get organised, so have placed some big hints around. It has also been noticed elsewhere that Gn15 is a bit quiet these days.
martin
Re: 2015 challenge
Postby martin » Mon Dec 22, 2014 11:49 pm
I may be wrong but I think the turnout/turntable rule is there to add operational interest.. I swonder if other prototypical mechanical line/route changing devices would be accepted?
(not that I think the rules need changing)
Re: 2015 challenge
Postby Simon » Tue Dec 23, 2014 10:36 am
Apologies for confusion - I was referring back to the original discussion of the mandatory turnout. Of course, being a bloke I never read the correct instructions fully (could this be reason for all of these unfinished kits?).
Anyhoo, planning has commenced properly and I think that it'll all fit...just. Mine will be a rock crusher/grader. Rock comes on in V skips, is tipped onto a conveyor that takes it up into the crusher, it then gets dropped (in the crushed form) out of a hopper into open wagons and is taken away. Am also trying to shoehorn a boiler house in so that coal can be brought in and tipped down the chute. Thus it will all have some prototypical operation even if it is all squiged into an area much smaller than reality. Lots of corrugated iron sheeting for the crusher plant should make it fairly quick to build.
Re: 2015 challenge
Postby rue_d_etropal » Tue Dec 23, 2014 10:06 pm
Simon says
I normally finish kits, but quite often, not as intended in instructions :roll:
NotHarryPotter
Re: 2015 challenge
Postby NotHarryPotter » Mon Dec 29, 2014 1:45 am
Hi folks,
so long as I fit within the stated width/height/length parameters, I am assuming that a traverser would be allowable? :?
Geoff
Re: 2015 challenge
Postby Colin Peake » Mon Dec 29, 2014 8:19 am
Mooching about in the shed the other day I happened to run a tape measure over a dismantled APA box... the depth when laid the way Ikea intended it is 14.5", so with a little shortening and something to bulk up the depth front or back... 8) :lol:
martin
Re: 2015 challenge
Postby martin » Mon Dec 29, 2014 9:40 pm
NotHarryPotter wrote:Hi folks,
Is that as a replacement to a turnout/turntable?
NotHarryPotter
Re: 2015 challenge
Postby NotHarryPotter » Tue Dec 30, 2014 1:01 am
Martin,
If you want the traverer as an alternative for a point then add it to list of requirements. I am just playing with ideas in my head at present.
If I can include a point as well then that is a bonus, but I am more just asking while I think of it.
cheers :D
Geoff
Return to “Challengnes”
