Longstone 2
Grum
Re: Longstone 2
Postby Grum » Sat Aug 26, 2017 7:53 am
Tom, has let me know of a possible problem with the photos at gn15.info/photo. The address he advised me to use on 15th July was an "https" address, but he think this may have a time limit or something linked to it. I may have to re-post images from an "http" address.
I have done the ones on this page, but whether I want to spend hours re-posting them all is another matter.
Graham
Grum
Re: Longstone 2
Postby Grum » Sat Sep 23, 2017 4:07 pm
Hello again, work continues at Longstone, although I haven't built any rolling stock, I have been quite busy arranging the Mill Board buildings. Meanwhile, I was wary that, during running sessions or exhibitions, my stock may decide to topple off the boards at certain points on the layout. I didn't want a tall perspex screen all around the layout, so I obtained several shorter lengths of acrylic perspex and polished the edges to get rid of the opaque line on the tops. My wife added bushes, shrubs and grasses to the inside of the perspex, above baseboard level, glued on with pva glue. To my surprise it sticks!? - and it can cleanly be peeled off and re-done if necessary.
From eye level, the horizontal edge of the perspex is virtually invisible, and from a standing position people can look over the screens without reflections. The scenic materials stuck on the inside gives the scenery and extra layer too. (Please excuse the walls and fences in the background)
Pictures below are of two of the new Mill buildings. Lots of details to add just yet, and in the yard etc, but they were made my "usual" way using foam board and Slaters 7mm Dressed Stone, with thin mdf for the roofs and added card slates. Windows are from York Modelmaking (their 0-105 Arch top windows) also using the extra template and the Stone Headers, the doors are scratch built with plasticard. The upper floor windows have been shortened by one pane height.
The stores/office building also has York windows (0-104). The hole in the end of the board will be obscured by a small third building.
These buildings have certainly taken-up a lot of time recently, and gone are the days when I can paint a small 5" size 4mm scale building in half-an-hour held on my finger tips, now it takes days and I feel as though I am holding a 9-month old baby in my lap!
Re: Longstone 2
Postby Bilco » Sat Sep 23, 2017 6:43 pm
It's all looking very nice Graham. The buildings have turned out really well - I like the algae growing on the damp stonework! I'm looking forward to seeing Longstone at an exhibition soon ...
southpier
Re: Longstone 2
Postby southpier » Sun Sep 24, 2017 9:31 am
really nice
http://gn15.info/photo/images/2017/09/23/DSC04875.jpg
any "under construction " photos?
Grum
Re: Longstone 2
Postby Grum » Sun Sep 24, 2017 5:44 pm
Thanks Bill, I do actually have a target date for Longstone's first exhibition - our NSNGM Groups open day/exhibition in Beccles on 3rd March 2018. Mmm, well, I'll just have to keep my fingers crossed for that one!
I'll look through my photos to see what "under construction" pics I have, and post them soon.
Graham
Grum
Re: Longstone 2
Postby Grum » Mon Sep 25, 2017 6:41 pm
I attach a photos of the Mill buildings below which hopefully shows the construction:
Parts for the stores and office building. Slaters 7mm Dressed Stone glued onto 5mm foam board with UHU. I lightly sand the rear of the Slaters sheets to help with adhesion. It can also be stuck on the edges of the foam board with UHU as long as the UHU has gone tacky (ie: not wet). The windows are also glued with the UHU. (I have used UHU for so long now - over thirty years - that several parts of me are stuck together with it)
Rear of the Mill building: The foam board was glued on with wood adhesive, strengthened with off cuts of the foam board. Roof and capping stones are 3mm mdf. Doors are scratch built with 30 thou plasticard.
I used Milliput to fill-in edges, and especially the corner joints where the stones meet, which (unlike brick) leave gaping holes due to the depth of embossing.
Painting the plasticard was done with eight colours of Humbrol, the card and mdf was painted with three Acrylic colours.
Graham
Re: Longstone 2
Postby lesmond » Mon Sep 25, 2017 6:44 pm
This is a lovely job, Graham, thank you for sharing.
Thanks too for the detail of the building construction - they are quite superb.
Re: Longstone 2
Postby docnjoj » Mon Sep 25, 2017 6:51 pm
Great work and hopefully inspiration.
Grum
Re: Longstone 2
Postby Grum » Mon Sep 25, 2017 7:18 pm
Thanks Les and Doc,
I know that my way of making things is not everybody's cup of tea. I chose to build in this way as it is relatively fast(?), also the stone work is similar to the area that I wanted to model, and it is very light weight, in fact if I could find something strong'ish to replace the mdf, I would.
Graham
Grum
Re: Longstone 2
Postby Grum » Tue Oct 17, 2017 2:32 pm
Spring Head Mill board.
I thought that things have moved-on sufficiently to try a few posed photos:
"Proteus" is seen shunting into the mill siding. I was hoping to to be able to protect the mill siding with a gate, but space didn't allow me to do this, so it's just a rusty old chain strung from post to post and a "No entry" sign hanging from it. The exit to the adjoining village board is masked off with a calendar picture in this photo. We chose to model the tree with old fashioned lichen at this point to stop small leaf foliage falling onto the turnout beneath...but looking at this image it appears that's failed then!
A view over the wall into the mill yard with "Delta" shunting. The small halt in the foreground is just for mill workers. The corrugated iron roof is home made with cat food foil dishes pressed on a former made of strips of old "n" gauge rail glued to a sheet of plastic. The yard lamps are heightened Lemax products. The ground cover was made with a mush ball of p.v.a, acrylic grey paint and fine sawdust, mixed with advanced lightweight filler.
"Triton" is about to leave the mill yard. My wife built the wall, and did all the scenic work.
I will have to add a few more details to the yard yet including some rubbish/scrap.
Re: Longstone 2
Postby Bilco » Tue Oct 17, 2017 4:20 pm
The Mill scene looks really good, Graham, and the locos are stunning. It's all those little touches of detail in the scene that make it stand out.
Re: Longstone 2
Postby docnjoj » Tue Oct 17, 2017 4:48 pm
beautiful and crowded, like life should be.
MickT
Re: Longstone 2
Postby MickT » Wed Oct 18, 2017 11:46 am
Outstanding work from both of you Graham! Congratulations and best regards to the boss!
Mick
Re: Longstone 2
Postby lesmond » Sat Oct 21, 2017 8:26 pm
Absolutely beautiful. Many congratulations to both of you for a superb job :)
Grum
Re: Longstone 2
Postby Grum » Wed Nov 01, 2017 5:20 pm
Thanks everyone.
I assembled to whole layout last week for a test run. Everything worked Okay apart from the Mill siding where I had "got my wires crossed" - literally.
Though scenically there are lots of little unfinished corners to attend to. I did take some photos, but they were either spoiled by the direct sunlight that day, or looked awful because of all the junk under the car port where I erected it!
This week I have been painting birds, they have all been prised-off Lemax figurines and ornaments. I have two Vultures from the Spooky Town series that I don't really know what to do with, though I'm sure someone will give me a suggestion or two.
Today I have been making the layout sign board.....the least said about that the better.
Graham
Grum
Re: Longstone 2
Postby Grum » Fri Nov 03, 2017 2:55 pm
Birdies...
My attempt at a few birds and animals for "Longstone", (though not exactly to scale). Dipper & Song Thrush. Chaffinch, Greenfinch, Starling, Blackbird, Sparrows. Rabbit and Squirrels. Crows. Jay & Collared Dove. The birds have been cut from Lemax figurines, I found the rabbit and squirrels (and several other animals still to do) from Vivid Arts "Miniature World" ornaments in a local garden centre.
I finished the sign board for the layout! After priming a bit of mdf, I decided to use a Plastikote aerosol to try to get a smooth surface for some vinyl letters, but I found it very thin and it took a long time to dry, even in a warm environment. Three days, six coats later and a few "runs" along the way I got to a stage where the board was coloured and smooth. I applied the letters, which were child's play by comparison, as they were applied with a fitted application tape ready positioned and spaced. Letters were made be Humberston Signs (SnappyGrafix) via Ebay.
Graham
Re: Longstone 2
Postby lesmond » Fri Nov 03, 2017 6:51 pm
Excellent :)
Re: Longstone 2
Postby Bilco » Sat Nov 04, 2017 8:19 am
Very nice Graham - those Lemax birds are very useful ...
Re: Longstone 2
Postby michael » Tue Nov 14, 2017 4:58 am
Hello Graham, I just read through your entire build. I like a lot of the small details and Like Chris was impressed with the backdrop scenes in the road next to the store. I also like the colour of your locos and coaches. I will be doing some rework myself on an old layout and as some mentioned in one of the posts there is a lot of merit in building a small layout. I enjoy the building as much as anything.
Anyway I will follow along with your updates.
cheers Michael
Grum
Re: Longstone 2
Postby Grum » Tue Nov 21, 2017 4:49 pm
Thanks Michael.
I can do "small", honestly. During my 009 days (2014/15) I built this little competition layout:
It is 19" x 17" and called "Raven Gill". Behind the castle tower or "folly" was a two-road sector plate to change the trains. It is in fact a virtual copy of an earlier layout built even smaller, in "A3" paper size. It is fascinating trying to design and build a layout in such a small space, and many parallels can be made with designing Gn15 scale layouts to get an interesting layout in a reasonable space.
I have taken my normal course even with Raven Gill though, trying to get as long length of run as I can, simply to make it better to run (for me anyway) at exhibitions. The layout now lives in Kent.
I have been painting figures on and off for the past few days. I like doing all the tasks in creating a layout, but I hate painting figures, I did when I modelled in 009, and I still do now. So, to relieve the tedium I started to build a new bogie vehicle for Longstone.
It is up on timbers supports while Bert and Howard do some finishing touches to the bodywork in the maintenance shed. It will be half open coach and half guards van. I am trying to get some suitable bogies for it at the moment, well.... I have some, but it seems they require some brass bearings to make the wheels fit properly.
It was a card kit given to me by a friend in our modelling group and I have to send him a picture of the completed vehicle when it is finished.
Re: Longstone 2
Postby PeterH » Tue Nov 21, 2017 7:18 pm
That’s gorgeous. Just what a small railway should be. Bert had better keep that flame away from the woodwork.
Re: Longstone 2
Postby lesmond » Sun Nov 26, 2017 9:53 pm
Beautiful. Thank you for sharing.
Grum
Re: Longstone 2
Postby Grum » Tue Dec 19, 2017 12:23 pm
Over the last few weeks I have been making odd details for the layout, painting figures, making wagon loads, boxes, sacks, etc. Nothing too extraordinary. Many of the figures - mainly the cheaper seated Chinese ones - have now been added to some passenger coaches. And, as an excuse to try out a new camera, here is a photo of some of the remaining un-fixed items.
Figures are various makes, all have been re-painted: A Chalk Garden Railway Guard, Preiser Elderly Lady, little girl with teddy (unknown make) found cheap at an exhibition, two Deans Marine figures (terrible brittle plastic and out-of-proportion limbs and heads) and three Chinese seated figures. Various cartons (given to me by a friend), barrels, Sidelines sacks and large Wool sacks made from Das clay.
I was surprised, as some of the Chinese figures came out quite well, though I am still trying to master techniques.
It seems I now have at least five exhibitions to attend next year with the (I hope) complete "Longstone" layout:-
Memorial Hall, DEREHAM - February 24th
Blyburgate Hall, BECCLES - Norfolk & Suffolk Narrow Gauge Modellers Open Day Exh. - March 3rd POSTPONED DUE TO SEVERE WEATHER
Barton Le Clay Village Hall, BARTON LE CLAY, Beds & Bucks Narrow Gauge Modellers Open Day - May 13th
Bressingham Steam Museum, BRESSINGHAM, "Narrow Gauge East" - June 2nd
Colchester County High School for Girls, COLCHESTER, Colchester Model Railway Club - 28th October
Best Wishes to you all for Christmas and the New Year
Graham
Re: Longstone 2
Postby PeterH » Tue Dec 19, 2017 7:00 pm
Hi Graham, I’ve just looked back over this thread. Nice work, you’ve achieved a lot in just a year. I wish you both well for the exhibitions.
Grum
Re: Longstone 2
Postby Grum » Wed Jan 10, 2018 7:49 pm
Last Saturday we (the Norfolk & Suffolk Narrow Gauge Modellers) held a "modelling day" for our monthly meeting. As I have our first exhibitions with "Longstone" in just over a month, I, along with my wife, took the whole layout along for a practice run, and to fix some figures on. Here are a couple of photos taken on the day. Please excuse the horrid orange chairs and clutter in the background of the first photo.
Fox Gill and the Village
Spring Head Mill
We still have to make the curtain around the layout, although the signboard is done and not visible in the photos. Trains, electrics, couplings performed well, there is just some tweaking to do to help with erection of the layout, and a couple of scenic items still to add.
I took delivery of some SLM online Model Citizens the other day, wow! they are brilliant. I just hope my painting of them can do them justice.
