Crundells Estate
backwaterscotland
Interests: Emett-esque GN15
Crundells Estate
Postby backwaterscotland » Wed May 31, 2017 2:35 pm
I know estate railways are a fashionable around here at the moment and here's another one :D
I started planning this a few years ago when I saw a photo of the shed at Duffield Bank and the multi level aspect appealed so I've been picking up bits and pieces towards this. The big impetus was the acquisition of a ready made set of baseboards - I built these a few years ago as end boards for a 00-gauge layout but they have now been replaced with laser cut ones so I took the old ones back. The photo below shows the boards as built and they make a circle around 6'6" in diameter.
The plan is to make 1 board "inspired by" the shed at Duffield Bank and make the other boards some nice scenery and a small fiddle yard. I'll mostly be making things up as I go along.
The name "Crundells Estate" is, as usual for me, a discworld reference. Crundells is the country estate of the Ramkin family and it is described as "a large rambling stately home profusely ornamented with statuary of naked women" so some of those may appear at some point.
Andy 8)
backwaterscotland
Re: Crundells Estate
Postby backwaterscotland » Wed May 31, 2017 3:38 pm
I actually started this a few weeks ago so the initial progress might seem fast.
I built up the levels for the shed board using plywood, topped with cork and laid track. The point motors have been fitted and the wiring droppers installed. Track is Peco 0-16.5 with a couple of Code 83 inspection pits used for inside the shed. A second board has a long curve running back down to "ground" level.
The track has had a quick weathering with a mix of grey, red and black spray paint and the sleepers brush painted brown. The white card sections are where retaining wall will be.
I've not yet decided what will be on the other two boards as yet or even what will be on the "long curve" board scenically.
Andy 8)
Postby chris stockdale » Wed May 31, 2017 4:20 pm
A fine start.
Those baseboards add up to quite a reasonable bit of real estate so there's no shortage of room to show off, ahem, do some great modelling.
Postby PeterH » Wed May 31, 2017 9:25 pm
Great. I'll follow this with interest.
Postby Jon Randall » Thu Jun 01, 2017 4:53 am
Splendid start 8)
Kerluk
Postby Kerluk » Thu Jun 01, 2017 8:41 am
Well done. Can't wait for the next pics.
Postby KEG » Thu Jun 01, 2017 10:00 am
Its about time, Ramkin Hall / Crundells gets an Estate Railway https://wiki.lspace.org/mediawiki/Crundells
After all, there is a standard gauge railway line from Ankh-Morpork to Quirm nearby.
Postby docnjoj » Thu Jun 01, 2017 10:37 am
Um...............looking forward to the statues!
backwaterscotland
Postby backwaterscotland » Fri Jun 09, 2017 10:55 am
Managed some progress. I've built up some of the hills and banks using polystyrene cut with a hot wire, newspaper and PVA glue. It's then had a quick coat of brown emulsion to see how it looks.
I've also started mocking the buildings up from foam board - good thing I did as the shed height, to scale, was a little too low to get the loco in so I had to add about 15mm to it. Hoping to get some mounting board this week and start constructing the building properly.
My first completed "estate" loco can also be seen, this is a Smallbrook Harlequin built pretty much as per the instructions.
Andy
backwaterscotland
Postby backwaterscotland » Fri Jul 07, 2017 2:55 pm
Slow progress but progress none the less. The mock up buildings have been replaced by their actual counterparts. The shed is artist mounting board with slaters embossed plasticard either side while the big building is mounting board and plasticard with a wooden supporting frame of 8mm stripwood.
I've started building up the concrete level inside the shed and once this is done I can start ballasting and scenics.
Andy 8)
Postby docnjoj » Sat Jul 08, 2017 1:42 pm
this is starting to look like a very classy layout. I'm following it for sure.
Kerluk
Postby Kerluk » Sat Jul 08, 2017 3:16 pm
docnjoj wrote:this is starting to look like a very classy layout. otherDoc
You're absolutely right.
docnjoj wrote: I'm following it for sure. otherDoc
Me too !
backwaterscotland
Postby backwaterscotland » Sat Aug 19, 2017 4:11 pm
Due to family visiting, Crundells was stored away for a few weeks but I've dug it out again and made some progress. The buildings have had their main colours painted and the start of weathering applied. I've been experimenting with Vallejo Air paints with the airbrush and it looks pretty good.
Most of the ballasting has now been done - I need to sort out the ground level at the front before finishing the front two tracks.
Andy
Grum
Postby Grum » Thu Aug 24, 2017 9:42 am
It's really nice to see a good idea forming, and on a large'ish layout too. I really look forward to seeing further postings.
Great! Andy
Graham
backwaterscotland
Postby backwaterscotland » Fri Nov 10, 2017 9:46 am
Progress is continuing but much more slowly than I'd like. The "shed" board now has all of the buildings in place and the basic scenery done. I still need to sort the roofs, fit the doors and do some detailing.
I've also made a start on the next board by carrying the levels across from the shed board. I now need to decide what is going on this board - my current thought is just a rising hillside with, maybe, a folly on it.
Andy
Postby lesmond » Fri Nov 10, 2017 10:08 am
Very gnice - good progress, I especially like the trackwork :)
backwaterscotland
Postby backwaterscotland » Thu Nov 30, 2017 1:24 pm
More progress. The next board (to the right of the shed board) is going through a brown phase. Hillside built up from polystyrene sheet covered in newspaper and PVA then painted brown. Still not completely happy with the contours, especially in the cutting, but getting there.
The hexagonal building is a hermitage based on the one at Painshill Park : https://www.flickr.com/photos/julesfoto/15535353880/ while a standing stone will be on the mound at the top of the hill.
The bridge is a 3d print using drawings from thingiverse, printed by a friend on his new 3d printer. Not convinced about the round bits on the handrails and it still needs some clean up and painting.
Andy
Postby PeterH » Thu Nov 30, 2017 6:32 pm
That’s looking good. I’ve made landscape with polystyrene (the cheap white bead kind) and I didn’t glue newspaper on it. I shaped it by picking bits of foam away to give a roughish surface, which looked sufficiently like ‘dirt’ when painted.
backwaterscotland
Postby backwaterscotland » Thu Nov 30, 2017 10:14 pm
Thanks Peter,
I've tried doing scenery with just polystyrene in the past and it works fine for a static layout but bits tend to break away in transport and you end up with a white patch. Covering it in newspaper gives a hard shell that resists damage a little although the edges of the newspaper pieces do sometimes show as can be seen. Most of it will end up covered in static grass eventually.
I got my polystyrene from the local wickes DIY shop in a 8' x 4' x 1" sheet and cut it with a hot wire cutter.
Andy
backwaterscotland
Postby backwaterscotland » Sat Jan 27, 2018 3:02 pm
I've knuckled down the last week or two and got all of the track laid and the wiring done. I've also worked out how the scenery is going to work.
The two new boards are the garden board which will be inside the walls of the estate with some lean-to greenhouses and a siding :
The fiddleyard board which has a loop with some isolating sections and a couple of sidings :
The whole layout will look like this :
And finally, the reason you never see photos of layout undersides showing the wiring :
I've also been set a target for the layout which is Model Rail Scotland in February 2019
Andy 8)
Postby PeterH » Sun Jan 28, 2018 6:53 pm
:D
Postby Jon Randall » Mon Jan 29, 2018 7:48 pm
Looking smart 8)
ian holmes
Postby ian holmes » Tue Jan 30, 2018 6:01 pm
Really nice looking layout.
Model railway psychic nutjob
Postby lesmond » Tue Jan 30, 2018 7:32 pm
Excellent progress. Good to have a target, and thanks for the update :)
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
