View from driver of BE loco
Similar shot with open tunnel side blocked off. Adding tunnel lights is one of the tasks to be done
The very large concrete agitator which must be used to test clearances
The new tunnel supports. The loco has arrived at the workface with the newly refurbished bogger which is being uncoupled and moved forward onto a set of temporary rails so the workface can be worked
