Prof Klyzlr wrote:Dear Gavin, Glen, Paul,
Best of luck at the show!
(4 hours drive then another 3.5 hours on the ferry, then another hour or more drive to where the exhibition is)
Adrian wrote:G'day Glen(4 hours drive then another 3.5 hours on the ferry, then another hour or more drive to where the exhibition is)
Is that all ?
Is that all ?
Used to drive to Newcastle (about 14 hours drive every year for about 12 years or so).
Also have done four shows in Sydney ( about 12 hours drive ) over a five week period.
Have also done shows in Adelaide ( 10 hours ) and Brisbane (took 3 days for that one )
And you worry about a little 9 hour journey with a rest in the middle of it !![]()
Arrr. The things we do for our hobby.![]()
I neglected to mention that that the Ferry cost is $600 return for a car.
Gavin Sowry wrote:Don't build it on legs... you need some baseboard on which to 'catch' any derailments. A 4" fall to the table top, is less damaging than a 3' fall to the floor.
Sir Briand wrote:Gavin Sowry wrote:Don't build it on legs... you need some baseboard on which to 'catch' any derailments. A 4" fall to the table top, is less damaging than a 3' fall to the floor.
The Narrow Gauge Madness gang here in the wilds of Ontario have pretty much settled on tabletop layouts. Makes for easy construction, fewer things to haul to a meet and the organisers provide the tables. K.I.S.S
Mark you, not all tables are the same height but that is not a problem if you only need 1 table for your layout.
In contrast to that new one, I have one purchased in late 1980s and it won't go through turnouts - back to back spacing of wheels is too tight by a few mm, or even 1/16+ of an inch, and axles are not quite long enough to pull wheels out, especially the drivers - there's some Ry's 4-6-0 dismantled in a box; it was going to become and On30 engine. The other Hornby steamers are buried in the closet in original boxes.DCRfan wrote: a new Hornby Flying Scots loco.
