(F) Underground! -- APA
Postby KEG » Wed Oct 19, 2011 1:16 pm
I never liked the square corners in modular boxes. So I started building a cave, to run my trains trough.
Used some liquid foam from a rattle can plus some thinner. No colour yet, exept a light black mist from a can. Powdered some rust pigments into the wet paint.
How big are those mouseholes?
Big enough for my Gn15 trains!
Postby KEG » Wed Oct 26, 2011 6:17 pm
Postby KEG » Fri Nov 11, 2011 4:33 pm
It is about time, to get some light into my caves. At the moment I can only effort to hire a worker with a flickering torch:
More pictures of my APA Box caves are here: http://www.die-feldbahnsinnigen.de/forum/viewtopic.php?f=22&p=3287#p3287
I used mainly a mixture of salt and flour on a styofoam base for the rocks. Dyed the mictures with pigments or / and Nesquick chocolate powder. Takes about a week to dry but is cheap and amazing.
Postby KEG » Sat Nov 12, 2011 8:14 am
I found the mixture at the local Kindergarten. After all, it only costs less than one Euro for 2 Kilos of modelling material. Some folks say, it tends to collect moisture from the surrounding after drying, so I might have to seal it with a suitable varnish.
At the moment I am trying to find suitable lighting. With room / exibition light it is too dark and too grey inside of an APA Box. On the other hand, bright flood light is not really something, you´d expect in a cave.
I suppose, light and colour design will keep me busy for a while. One thing is certain, it is almost impossible, to show the beauty of a cave on photographs. Whenever you change the light, colours and shadows are changing as well in a dramatic way.
Meanwhile an earthquake broke away part of one of the cave´s walls.
The inside of the APA Box looks a lot larger now.
Postby KEG » Sun Nov 13, 2011 8:45 am
I do have sources for special effect LEDs, but do not really aim at a Disco or Disney Land lighting.
A window or an arch with a picture of the world outside is a common theatre trick to create the illusion of depth. After all, APA Boxes Dioramas are only (very small) 3-D pictures, a miniature stage more or less.
In my case, I simply glued a print of an early 19th century painting (Andreas Achenbach, 1834) to the rear wall, covered it with plastic from a shopping bag, before modelling the flour / salt rocks. When dry, I removed the plastic cover to reveal the backdrop.
Juergen.
Postby KEG » Mon Oct 07, 2013 8:02 am
Recently I tried to combine the end loops of my deskop layout with an APA Box, I built 2 years ago. .
http://www.die-feldbahnsinnigen.de/forum/viewtopic.php?f=57&t=562&p=6397#p6397
The idea is, to have an extra track, maybe with a fiddle yard, behind the box(es).
Maddog
Interests: Gn15, Narrow Gauge, Carson & Colorado/Slim Princess, Virginia & Truckee, Denver & Rio Grande, Uintah Railway, Death Valley
Re: Underground!--APA
Postby Maddog » Sun Oct 25, 2015 3:33 pm
KEG wrote:I found the mixture at the local Kindergarten. After all, it only costs less than one Euro for 2 Kilos of modelling material. Some folks say, it tends to collect moisture from the surrounding after drying, so I might have to seal it with a suitable varnish.
Try looking at some photos of Carlsbad Caverns for ideas (http://www.americansouthwest.net/new_mexico/carlsbad_caverns/national_park.html).
Re: (F) Underground! -- APA
Postby KEG » Sun Oct 25, 2015 10:11 pm
Thanks for the hint. But I gave my two underground cave APA Boxes away.
For my purposes, the APA Boxes proofed to be too small.
We are using larger boxes for our diorama modules. http://www.die-feldbahnsinnigen.de/forum/viewtopic.php?f=44&t=1710
Return to “GnAtterBoxes”
