Sources of figures
Kevin
Postby Kevin » Mon Dec 05, 2011 7:08 pm
The adult hedgehog is huge but the
baby is not too bad for a model of an adult.
Postby michael » Tue Dec 06, 2011 4:10 am
Juergen said
But don´t expect me, to built a new layout, everytime some new figures come around
Definitely caused a laugh Juergen!
Juergen it seems to me that you create layouts all the time!
I have never seen an overall plan of your layout in all the time I have watched your amazing collaborations of timely and specific productions of scenes.
You are one very creative modeller!!
Postby KEG » Tue Dec 06, 2011 7:29 am
have never seen an overall plan of your layout...
Never had a plan or a Gn15 layout. Only a few hundred figures and some backdrops- Plus a 4 square meter garden.
Recently I was playing with a cave and some track in an Ikea APA Box.
http://www.die-feldbahnsinnigen.de/forum/viewtopic.php?f=22&t=564 The light in there seems to change every minute.
backwaterscotland
Interests: Emett-esque GN15
Postby backwaterscotland » Wed Dec 14, 2011 12:15 pm
I've been messing around with some Bachmann Big Haulers figures, to be exact the Engineer (Sitting) figure.
From left to right - figure as bought, my modified figure, Schleich 4x4 driver (now discontinued?).
The bachmann figures have a body/legs made of a hard plastic with a rubbery plastic used for the head and arms. Both plastics seem to stick alright with superglue though. Modifications to the figure are straightening him up, moving the arms and removing the hat and gauntlets.
Scale wise, they come out as being just over 5 feet tall in 1:24 where the Schleich figure comes out as around 6 feet - not sure if the bachmann figures are under scale or the Schleich figure overscale or both.
Andy 8)
Postby Steve Bennett » Wed Dec 14, 2011 1:32 pm
backwaterscotland wrote:Scale wise, they come out as being just over 5 feet tall in 1:24 where the Schleich figure comes out as around 6 feet - not sure if the bachmann figures are under scale or the Schleich figure overscale or both.
Cant speak for the scale of the Bachmann figures, but they look close to 1:24. The Schleich ones though are intended to be 1:20, so yes they are overscale, but usable with care and can be chopped around as you have seen in other threads.
Booga
Interests: Narrow and minimum gauge railways, currently modelling O-16.5 but this site inspires me.
Postby Booga » Fri Jan 06, 2012 8:27 pm
gfadvance wrote:It may be of interest but I have recently started using this stuff
http://www.totalwargamer.co.uk/filla-gl ... e-10g.html
It has all the usual properties of standard superglue but the addition of rubber does seem to do what it says on the tin, its does provide a degree of flexibility and also acts as a filler.
Thanks for the link, Gordon. Do you know if it can be filed to shape when it is dry?
Hello, I'm Dave.
So many modelling ideas, so little money!
Postby gfadvance » Sat Jan 07, 2012 2:13 pm
Dave, certainly the stuff I use can ............... although where I have used it where for example the seam is less than perfect when 2 pieces are brought together then I have started to wipe the joint afterwards with a superglue debonder which just alleviates the need to sand at all
Booga
Postby Booga » Sat Jan 07, 2012 7:51 pm
Thanks for the tip, Gordon. I've ordered some so will give it a try, my Chinese "man with suitcase" has been chopped and filed and is just waiting to be stuck together to make a driver. :)
Hello, I'm Dave.
Postby gfadvance » Sun Jan 08, 2012 10:59 am
Was going to post this on the Bottom Yard thread but its buried pretty deep now :roll:
I needed some 1930's to 1950's "British" workmen in the proper scale so decided to play with some of the SLM figures in the spares box.
The origonal is obviously the left hand figure , following a bit of surgery to reduce his height to a more realistic 5' 8" added a flat cap, a waistcoat ... the fleece of its day seems to be worn by about 90% of workmen in the photos I have looked at, and added some detail to his boots
Image Image
A bit of a paint job and he has ended up like this
Image Image
Image Image
Of now to see what we can do with the right hand figure as well as sorting out their infamous seated driver ( just for you Mr Mott :wink: )
Postby henrix72se » Sun Jan 08, 2012 11:17 am
GREAT !!
One of the best jobs I've seen in a long time.
What material did you use for the waistcoat and the other adds ?
Postby Gerry Bullock » Sun Jan 08, 2012 12:01 pm
Superb Gordon, same question from myself as that of Henrik's?
Postby Jon Randall » Sun Jan 08, 2012 12:07 pm
Is it Games Workshop "Green Stuff" :?:
Dallas_M
Postby Dallas_M » Sun Jan 08, 2012 12:33 pm
Very nicely done, Gordon!
Dallas
Dallas Mallerich
Boulder Valley Models
www.bouldervalleymodels.com
Postby gfadvance » Sun Jan 08, 2012 3:18 pm
Glad you like him ................ amazing the number of faults you notice after you have posted the pictures, need to sort out some of the paint work around the belt, etc.
Most of the modifications were done with Milliput, , http://www.fredaldous.co.uk/milliput-standard.html , the rest with wire and 5 thou plastic card
Now you either love this product or hate it ............. me I like it because you can roll it out into thin sheets as long as you dust your surfaces with some talc. Its water soluble so you can blend in with a damp brush & push /prod into folds etc ............. and if you gently heat with a hair dryer you can speed up its setting time.
The waist coat was made of 3 separate parts, left & right front and a back cut roughly to shape following a paper pattern previously made up ..... dampen body and then apply letting each piece harden off a bit before moving onto the next bit .... with a bit of heat doesn't take long, all the work on this figure was completed in a couple of hours.
One tip I would suggest is that if you purchase it cut the rolls of putty into smaller lengths and either place in sealed plastic bags or wrap in cling film .......... this just helps to stop it all drying out to quickly.
Postby Boghopper » Sun Jan 08, 2012 3:26 pm
I agree Gordon. When I was modelmaking for a living, I often used it. Not only was it easy to work when soft, it could be carved and drilled when hard. Very versatile.
Postby Adrian » Mon Jan 09, 2012 3:18 am
G'day Gordon
First regarding your figure .......
WOW !!!
I am about to have a go at building a model rat for my Acme layout ..... and after going to various craft and model shops finally finished up with a pack of Milliput.
Everything else was out of stock.
Nice to see that it is the same stuff that you use ..... so if the model doesn't come out right I know that its me, not the material :oops:
Thanks for the working tips and the storage tip about the Glad wrap.
Postby gfadvance » Tue Jan 24, 2012 8:16 pm
This came up on another forum .......... not available yet but should be really useful & a great idea
http://www.armorama.com/modules.php?op= ... 06#1564822
http://s1181.photobucket.com/albums/x42 ... aleArmory/
Postby Gerry Bullock » Tue Jan 24, 2012 8:39 pm
Looks good Gordon maybe I'll try one once they're available.
More resin figures from China have surfaced in Doll's House half scale.
The new ones are up-market women that might suit any Heywood style layout. :wink:
They can be found here.
Postby Jon Randall » Wed Jan 25, 2012 2:37 am
Thanks Gordon & Gerry, they'll both come in handy 8)
Postby michael » Sun Jan 29, 2012 5:08 pm
Great job Gordon.
MrPlantpot
Postby MrPlantpot » Thu Mar 15, 2012 12:21 am
Booga wrote:Image
Has anyone any experience of using this figure?
I have; see top of page 2 here: http://forum.gn15.info/viewtopic.php?t= ... c&start=25
I got 24 figures from China, different seller name, but I think some of them have several eBay accounts, so it might be the same one.
Hope this is of some help/inspiration :D
My Mum calls me Steve.
Postby gfadvance » Tue Mar 27, 2012 9:17 pm
Now I know these figures are 1/35
http://www.finescalerr.com/smf/index.ph ... 3#msg33003
But have been in contact with Michael and he is prepared to consider doing them or variations in 1/24 .
BUT he is a small producer and needs to be able to have some idea if there is a real interest.
So if he has created a facebook item for people to register their interest and choice of new scale ............. there is no commitment to buy its just a way of seeing potential market
http://www.facebook.com/IndustriaMechan ... 9714912241
If you are not on facebook and don't want to join send me a PM and I will register your preference .
I have no connection with this company, only an interest in trying to get some new and different 1/24 figures out in the market .
Postby Little Andi. » Tue Mar 27, 2012 10:46 pm
Gordon....................
As mentioned in the original thread - can you formally register my interest in a 1/24 set for me?
Taa.
Postby gfadvance » Wed Apr 04, 2012 7:07 am
Just to let you know that the "deckhand" figures http://www.finescalerr.com/smf/index.ph ... 3#msg33003 will be made available in 1/24.
Still waiting for availability date but should be fairly soon.
Thanks to all of you who registered an interest ....... people power :D
Postby Little Andi. » Wed Apr 04, 2012 7:51 am
gfadvance wrote:Just to let you know that the "deckhand" figures will be made availble in 1/24.
Still waiting for availablility date but should be fairly soon.
:D
Brilliant - Let me know when, and if it suits it might be worth doing something with the shipping.
Excellent intermediary skills. 8)
