The GnATTERbox Forum Index The GnATTERbox
Gn15.info's discussion board
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Get your merchandise here!
I'm probably going to regret this...
Goto page 1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    The GnATTERbox Forum Index -> Size doesn't matter
View previous topic :: View next topic
Author Message
Will Vale
Friend of Gn15.info
GnatterBox CenturionSeasoned CampaignerFriend of Gn15.info
PostPosted: Fri Oct 09, 2009 8:00 am    Post subject: I'm probably going to regret this... Reply with quote
...but something is afoot on my kitchen table:
It all looks a bit cabalistic really, with the crossed sleeper strip and arcane geometries of the bits of rail and on the cork. Twisted Evil
You can also see my Mk2. rail bender - the Mk1. was my finger and thumb but I cut myself on the rail web quite unpleasantly last time - hence the small piece of cardboard for this attempt. Safety first!
Apologies for the protracted absence, I've been doing standard gauge stuff (layout in progress, some rolling stock weathering, etc.) and have rather neglected the minimal gauges in the meantime. Hopefully this project will provide a bit of light relief Smile
Will
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
Old Timer
Author
MillegniumerOld TimerAuthor
PostPosted: Fri Oct 09, 2009 8:35 am    Post subject: Reply with quote
Display card - not being used as intended.
Track - not being used as intended.
You have made a perfect start Laughing Laughing
_________________
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Fri Oct 09, 2009 9:46 am    Post subject: Reply with quote
I failed to summon any demons with my arcane geometries, and ended up with this instead:
It moves! And the wiring was a bit of a relief after the DCC madness of my other project. Two power wires, two frog wires in case I want them later, and one insulating joiner.
It's not the most exciting plan, but it's hard to do much with sidings if you want an oval as well in the given area (A3). The idea is that the back half will be tunnels with a modelled scene at the right rear, a connecting track through an open-backed engine shed on the left, and a spoil tip at the front left. Not a lot of operational possibility, but it'll certainly work and it might be possible to automate loading at the top right and tipping at the front left at some point in the (far far) future.
Laying the track onto cork with nothing else under it is quite fun - it makes it easy to change things, but it's just about strong enough to keep everything in the right place. It's now been trimmed back and laminated to some thin MDF since I like to have something solid to fix things to if I need it.
Will
Back to top
Old Timer
Author
PostPosted: Fri Oct 09, 2009 7:40 pm    Post subject: Reply with quote
It doesn't look like the regret is getting in the way so far Wink
_________________
Back to top
View user's profile Send private message Send e-mail
Multi-Millegniumer
Old Timer
Author
Friend of Gn15.info
Multi-MillegniumerOld TimerAuthorFriend of Gn15.info
PostPosted: Fri Oct 09, 2009 9:18 pm    Post subject: Reply with quote
Ah, the pleasures of a small oval of track Smile cant beat it Laughing
_________________
http://www.pepper7.co.uk
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Old Timer
PostPosted: Fri Oct 09, 2009 9:34 pm    Post subject: Reply with quote
A3 size you say.
Is this for the NZ Model Railway convention competition next year?
_________________
Glen Anthony.
Gnew Zealand
"The Stamping Ground"
http://www.trainweb.org/nzgr/Gn15/Gn15.html
Back to top
route29
True GnATTERboxSeasoned Campaigner
PostPosted: Fri Oct 09, 2009 11:19 pm    Post subject: Reply with quote
Looks great so far!
_________________
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Sat Oct 10, 2009 7:34 am    Post subject: Reply with quote
Thanks for all the comments!
Hmm. I certainly picked the size with that in mind, but as for entering, it depends how it comes out... I should add that I was really impressed by the incredible speed with which you built the latest bits of your layout and that was a big spur to get started on this one.
I still feel a bit bad though (the regret thing) - I'm neglecting my OO, and that was supposed to be a quickie project in itself... At least it's reached a coherent stage (all track down, wired, painted, working) rather than being at different stages in different areas, so it should be easy to go back to it and start in on the scenery later. Plus I have to weather many many items of stock before it's 'ready' which is going to take a year or so.
Never was a truer word spoken. Of course, my next job is to disguise the oval - I think there's a sort of 'secret shame' thing at work with ovals - we all like to see the trains go round, but there often has to be an excuse - a tunnel, shed, wall, or something to hide the awful truth Smile
I got the point polarity switches in today, I'm off to wire them up in a minute and then hopefully cut some foam and fit the track base to the board proper.
The front points are worked by a rod (stiff piano wire) running diagonally under the board to clear the hole. It slides in guides made of the innards of cotton buds epoxied to the MDF, which stop it popping out of the tiebar at one end, and make the switch action a bit more reliable at the other. There's a gap between the end of the guide and the tiebar to allow the rod to flex enough to cope with the change in direction between the tiebar and it's own axis.
Not rocket science, but it works and is direct enough that changing the points manually switches the microswitch, as well as the usual way around. I need to be quite confident about it, since it'll be buried in styrofoam and completely inaccessible - all the difficult bits (switches) are on the surface which is supposed to help with this.
The rear points are worked manually and the end of the tiebar presses the plunger on the microswitch directly.
Will
Back to top
Old Timer
PostPosted: Sat Oct 10, 2009 8:35 am    Post subject: Reply with quote
You can buy curtain wire for about 99c per metre, and run the panio wire down the middle of it. It bends around curves more smoothly than and is quicker to put down than lots of cotton buds Wink
_________________
Glen Anthony.
Gnew Zealand
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Sat Oct 10, 2009 9:55 am    Post subject: Reply with quote
That's a good idea - thanks. I'll file it away for next time. Is piano wire that's fine enough to go around corners also stiff enough that you can just turn the end up and stick it through the hole in the tiebar?
(The cotton buds weren't too bad in this case since the wire run is dead straight - I only used a couple at key points.)
Back to top
chris krupa
Old Timer
Demi-MillegniumerOld Timer
PostPosted: Sat Oct 10, 2009 7:38 pm    Post subject: Reply with quote
I don't like piano wire since it is so hard that eventually it snaps (at least it has on one of my layouts - three times) due to the extra work hardening of point changing.
I prefer to use square section brass rod running in square plastruct tube. I find that brass has much less tendency to work harden and snap.
Certainly you can't take it around corners, but I think that doing so risks extra hardening and sooner snapping. I prefer to design the layout so the point rodding runs are straight.
Back to top
Old Timer
Author
PostPosted: Sat Oct 10, 2009 9:19 pm    Post subject: Reply with quote
Perhaps we should 'life' the piano wire - 500 pushes or pulls (or perhaps 499 given what happened below Laughing )
The link is to an article about a vertical bungy ride in the centre of Wellington which suffered a failed rubber bungy this week. It occured as it was being pulled down for assent number 500. The bungys are replaced after 500.
http://www.stuff.co.nz/national/2942070/Cord-snaps-on-Wellington-bungy-ride
_________________
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Sun Oct 11, 2009 6:18 am    Post subject: Reply with quote
Sounds like someone forgot to multiply by 1.5!
I've been testing my sanity today replacing some crazy-track sleepers with square timber for a bridge, and then fitting some chairs/spikes cut from On30 track. It's done now, but I pray they won't come off before I get some supporting bridgework underneath Sad
Edit: They're at least a bit overscale, and it's more noticeable than I thought. I think I might try and trim them back so that they'll just be wide rather than long... Hmm.
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Mon Oct 12, 2009 10:38 pm    Post subject: Reply with quote
Bit more happened over the weekend and last night:
I finished the wiring and got the point frogs powered. I made the usual mistake and put the iron away before testing - I'd forgotten to feed one side of the second siding from the frog of the first, so had a short when both points were set in a particular combination.
The wiring runs underneath and will be inaccessible, but all the termination is on the top so it should be possible to fix problems after the fact, or run new wires on the surface if necessary.
I then got the layers laminated up. When I built Igelfeld (the Z layout) I had a lot of trouble shaping the rising ground below track level since I glued the Styrofoam to the frame before shaping it so couldn't cut from both sides. This meant the river ended up exactly as wide as my pocket plane Smile
To get around this, I cut out the recessed portions of the terrain en bloc when the sheet was loose. The idea is to carve them on the workbench (kitchen table) and use the angled cuts as a key to put the pieces back in.
You can also see the deeper bridge sleepers in those pictures - what a fiddle they were!
I've also started boxing in the tunnel - this is a bit scary since it shows how much elevation I'm dealing with in a small area - lots of rocks required:
It's not quite as precipitous as it looks since the removable piece of styrofoam is intended to slope up from the front to the back - there won't be a near-vertical cliff, but there's still around 150mm elevation overall.
Finally I've painted the track, or at least made a start. Since this is a desert setting I figured the wood would weather to grey, so painted the track with grey primer. There was a bit of panic since it looked fairly terrible - I think the paint was quite old, or else it's just different to the Tamiya lacquers I've used for this before, and I didn't put on a very good coat - a few clumps. It didn't help that I was outside in the dusk at this point so had to guess quite a bit of what I was doing... Anyway, I've cleaned everything up and the trains are running OK. I then went and brush painted the rails and chairs with raw sienna tube acrylic, and it still looked terrible since any missed bits were bright rather than dark.
After that had dried I made up a dark wash from Tamiya thinners with GW black acrylic ink and "Devlan Mud" wash. The Games Workshop washes and inks have a great range of colours but they don't flow very well on large surfaces - adding the thinner (alcohol works too) rather than water makes a huge difference. I splashed this on liberally with a big brush, and at last it's starting to look like I imagined. (Phew Smile ) Next step is to touch up the rush and drybrush the sleepers.
Coming soon: Ballast, hopefully. I'm planning to use Klear for this as seen on RMWeb - I did a little test and it was pretty good, and less hassle than PVA since you don't need to wet it first.
Will
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Tue Oct 13, 2009 9:57 pm    Post subject: Reply with quote
I couldn't find a ballast colour I was happy with from my motley collection, so I tried an experiment. I mixed a relatively neutral ballast (Hornby light tan, which is a very slightly warm grey) dry with Mig Gulf War Sand pigment, and it works really well. The pigment seemed to adhere to the ballast so that when I spread it over the sleepers, it didn't rub off onto them. I dribbled on some Johnson's Klear and it set hard overnight. It's very slightly darker now that it's dry, which I guess is to be expected since Klear is gloss. There's no gloss finish on the ballast though.
One thing to watch is that if the Klear gets on the sleepers they will be slightly glossy. It doesn't creep, so it's just down to being accurate with the eye dropper. I got one glossy one, but it doesn't matter since my experimental section is in a tunnel Smile I suspect a light drybrush would kill the gloss very quickly, which is what I'll try - or I suppose you could always apply some matt varnish.
[edit]
A picture speaks a thousand words, so here's a cruel closeup. The ballast on the cardboard on the left is the dry mix, on the right is the result after fixing and drying:
I think it's possible to see a slight gloss on the grains at this level of magnification, but it's not noticeable at any kind of distance, and will tone down with more powders and/or drybrushing anyway. I'm happy enough with this result that I've gone ahead and ballasted the rest.
Will
Back to top
mud magnet
PostPosted: Wed Oct 14, 2009 5:02 pm    Post subject: Reply with quote
Will,
Track work and ballast looks great. Colours work well. I've been using the Games Workshop paints myself recently (having been using them for Warhammer 40,000 orcs and space rangers - another modelling interest with my 12 year old son) and have some good results. I will try the Tamiya thinners with the washes - useful idea.
Look forward to seeing progress.
_________________
Richard
Back to top
Multi-Millegniumer
Old Timer
Author
Friend of Gn15.info
PostPosted: Wed Oct 14, 2009 5:20 pm    Post subject: Reply with quote
Interesting the use of Johnsons Klear, not used that since I needed shiny boots in the armed forces, a long time ago Smile
Have you tried it with ground foam yet Will, curious as to wether it will penetrate without a wetting agent of some sort Question
_________________
Back to top
Pandy
Old Timer
GnatterBox CenturionOld Timer
PostPosted: Wed Oct 14, 2009 6:23 pm    Post subject: Reply with quote
Looks good to me ! will have to remember that one Smile Steve, I thought your lot all used Tornado nose cone paint on their toecaps Smile I've heard of it used in an attempt to stiffen combat jumper elbow & shoulder patches but never tried it myself.
_________________
Dave & Lorraine, more ideas than space, time & finance permit !
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Wed Oct 14, 2009 9:42 pm    Post subject: Reply with quote
I resisted the lure of the Evil Empire for more than a decade - I used to be into their games a bit in my teens and at college - but the new Space Hulk was too much. Until I started this layout my workbench was covered in these chaps:
I shouldn't complain too much - painting figures (then and now) was a great way to learn about paints and brushes and develop some fine motor control. And the new foundation paints are fantastic - they're thick in the bottle but even when thinned to a painting consistency they cover really well. Good for drybrushing as well without thinning.
I was thinking about that just now - I'll do a test and see what happens. My suspicion is that it might not penetrate, since I get the feeling it's on the edge for the ballast I'm using. Certainly I needed to take a little care dropping it on to avoid craters - it seems best to form the drop right on the surface of the ballast so it wicks away instantly.
There isn't a huge advantage of Klear over dilute PVA for ballast - it dries a bit quicker (6 to 8 hours for me) and doesn't require pre-wetting. It's very quick to do though, and handy since you can just use it neat from the bottle. Both dry with a slight gloss, Klear is probably a bit harder.
I think the no wetting is the main thing - saves a bit of time, and it's good for card + foamcard baseboards as often seen in these parts Smile
Will
Back to top
MillegniumerSeasoned Campaigner
PostPosted: Thu Oct 15, 2009 2:30 am    Post subject: Reply with quote
The track looks great will. I like the colour of the ballast combined with your sleepers, track and track ties Cool
That's a friendly looking set of figures you have there Laughing The folks here in Taiwan seem to like painting robot figures, alot of them in the model shoppy here Rolling Eyes
Good progress on the layout. The structures toward the back look interesting Cool
_________________
Back to top
Cross Kitter
PostPosted: Thu Oct 15, 2009 9:45 pm    Post subject: Reply with quote
Hi Will Vale and co,
I read somewhere, I've got over four hundred railway related publications Rolling Eyes so could have been anywhere Embarassed that one professional model layout builder actually prepares the baseboard as usual and then dry lays all the track and fixes it into the complete formation by soldering/gluing all joints and some sleepers to the rails (no I think he uses glue for the sleepers. Rolling Eyes ) He marks exactly where he wants the ballast to go onto the layout, removes the complete track (I'm guessing he does this in sections Question ) spreads neat PVA where he wants the ballast to go, puts the track back in place (he didn't say how he managed to get it in the correct position with all that white glue obscuring where he had put it before Question ) and then just pours ballast over the whole layout Exclamation
He waits 24 hrs for it to dry and then hoovers up the loose ballast with a dedicated hoover Shocked and recycles the ballast back into a container.
Not tried this one myself yet but especially with our small layouts and card that could fall apart with too much wet it does appeal to me.
Has anybody else tried it yet Question
_________________
Simon the "very" cross-kitter.
I know what happens if you cross a 1:48 loco kit with a 4mm chassis, only a mother could love it. If it's a kit I'll bash it, and use bits from anywhere in anyscale.
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Thu Oct 15, 2009 10:21 pm    Post subject: Reply with quote
I haven't tried that. I do stick my track down with PVA so I guess it would be possible to ballast at the same time. In fact for this layout the rail joints are all soldered (apart from one insulated joiner) so it *might* be possible to lift + replace the track. Like you say, I wouldn't be confident about my track being in exactly the same place after removal and replacement, given that even with pre-curved rail I tend to get some stresses at joints. I'd worry about not getting curve radii right, and minimum gauge tends to be closer to the edge in that department Smile
A couple of things to watch for if you give it a go:
* I can't imagine you'd get much depth of shoulder with a single layer of ballast on PVA. I noticed with the 009 track that the sleeper strip was quite evident and I needed to add a bit more ballast in a couple of places where it wasn't quite at sleeper top level in order to hide it.
* I've found that when gluing track with PVA, it's very easy to get heavy tarnish on the rail if there's too much glue or the air can't circulate. I don't know if the ballast would help this (absorb glue) or hinder it (require more glue). This might be something that only happens to me though - I've never seen other reports of it.
Not saying it wouldn't work though. I must also admit that I quite like the drudgery (Mrs. Doyle accent Very Happy) of diluted glue ballasting - it's hard on the eyes, but very satisfying to do.
W
Back to top
Multi-Millegniumer
Old Timer
Author
Friend of Gn15.info
PostPosted: Thu Oct 15, 2009 11:55 pm    Post subject: Reply with quote
Yes, and it looks crap Laughing all you get is a very thin layer of ballast, the glue doesnt penetrate far enough to get a decent layer plus it is not tightly packed enough to look right. You can also get similar results with double sided carpet tape which is a lot cleaner to use. I wouldnt recommend either method, but some people seem to like the results.
_________________
Back to top
Will Vale
Friend of Gn15.info
PostPosted: Fri Oct 16, 2009 4:43 am    Post subject: Reply with quote
I suspect it might be the same category who believe that working signals and point rodding are vital to the appearance of a railway. Neatness before all!
Back to top
Old Timer
Friend of Gn15.info
MillegniumerOld TimerFriend of Gn15.info
PostPosted: Fri Oct 16, 2009 3:57 pm    Post subject: Reply with quote
I have glued track and ballast down with this method using neat waterproof pva with success but supplemented with the pva/water/washing-up liquid after the bottom layer of glue has dried.
The rails did turn green though Rolling Eyes
_________________
Gno dear, I'm gnot building another layout.
Ok just one more for luck.....
Size is gnot the important issue here
Back to top
Display posts from previous:
Post new topic   Reply to topic    The GnATTERbox Forum Index -> Size doesn't matter All times are GMT
Page 1 of 6
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
