| View previous topic :: View next topic |
| Author |
Message |
Simon Andrews Millegniumer Old Timer Friend of Gn15.info
Joined: 04 Oct 2005 Posts: 1335 Location: Calne, Wiltshire, England.
Posted: Mon Jul 12, 2010 1:37 am Post subject: |
The stone blocks really look the part. Nice work Ian.
Simon. _________________
| Back to top |
Ian-IoM GnatterBox Centurion Seasoned Campaigner
Posted: Tue Jul 13, 2010 10:05 pm Post subject: |
Thanks for all the encouragement folks ,
I'm still here Andi - just a bit busy with real life stuff recently. Looking in on the forum every day though, and following the top and bottom yards with interest, and I'm sure I'll be stealing some ideas from them for my layout
Ken - Yup, I felt like a bit of messy fun: after the fiddly stuff with track building playing with sludged newspaper made a nice change
To be continued... _________________ Ian K
We're all pawns, m'dear. |
| Back to top |
Posted: Wed Jul 14, 2010 11:36 am Post subject: |
A spray with grey primer, a bit of balsa, and a play on the kitchen table:
Yo ho ho, and a bottle of rum... _________________ Ian K
| Back to top |
Posted: Fri Jul 16, 2010 8:08 pm Post subject: |
Harbour wall somewhere near now...
The stonework was sponged with a bit of browny grey (matt emulsion match pot), then given a wash of black, and some green on the lower half (both from a cheap kids poster paint set, 32 colours for £1.49 )
The balsa was attacked with a wire brush, painted with the same match pot emulsion and given a wash of black and a patchy wash of green, again more on the lower half. Here's a close up:
| Back to top |
Glen A Millegniumer Old Timer
Joined: 02 May 2007 Posts: 1163 Location: Christchurch, New Zealand
Posted: Fri Jul 16, 2010 9:19 pm Post subject: |
Good job!
That green is so subtle I didn't even notice it until I read it your notes and went back and had a second look at the pics.
But it makes it look very convincing! _________________ Glen Anthony.
Christchurch
New Zealand
I survived the Christchurch 7.1 earthquake, 4 Sept 2010.
"The Stamping Ground"
http://www.trainweb.org/nzgr/Gn15/Gn15.html |
| Back to top |
dieselwater Millegniumer Seasoned Campaigner
Joined: 21 Sep 2008 Posts: 1302 Location: Taipei, Taiwan
Posted: Sat Jul 17, 2010 3:14 am Post subject: |
Beautiful work Ian. _________________ Little old lines to somewhere.
David. |
| Back to top |
Kevin GnatterBox Centurion Seasoned Campaigner
Posted: Mon Jul 19, 2010 11:54 am Post subject: |
Ian,
I like that harbour wall very much. I have just started building a stone quay for my 7mm layout 'Dilligaf Quay'.
Like you, I was going to use egg box card, but now I'm going to steal your method.
I really like the heavy look of the stones using this method.
Just one question,
If you press the paper mixture between sheets of newspaper, how do you stop the newspaper soaking up the water and becoming part of the mixture?
Kevin _________________ Please follow the 'WWW' link to my Photobucket pages with pics of some of my Discworld miniatures and dioramas. |
| Back to top |
Posted: Mon Jul 19, 2010 2:59 pm Post subject: |
Here's a bit more detail:
The newpaper above and below the shredded stuff does become part of the finished thing. What I did was cover a piece of MDF with plastic sheet, lay a few sheets of newspaper on this, then spread the torn up paper mix on this, then put a few sheets of newspaper over the top. I pressed it all down well and the water/pva mix soaked in to all the paper and bound it all together. I used a block brush to tamp it down a few times while it was drying, and it took a few days to dry sufficiently to handle. I cut it up while it was still damp, and it took a bit of cutting - I wasn't joking about the plasters! At this point it was still soft enough to round off the edges of the blocks by squidging with the fingers. A bit more drying time, then I stuck the blocks onto the backing - a few fell to bits - perhaps I should have used a bit more PVA in the mix, so I then brushed a coat of slightly diluted PVA over the whole lot to bind it together.
Hope that helps  _________________ Ian K
| Back to top |
gfadvance Demi-Millegniumer Old Timer Friend of Gn15.info
Joined: 17 May 2007 Posts: 701 Location: Manchester, UK
Posted: Mon Jul 19, 2010 3:44 pm Post subject: |
Thanks for the additional info Ian ......... another idea that may well be borrowed  _________________ Gordon F |
| Back to top |
teetrix GnatterBox Centurion Seasoned Campaigner
Posted: Mon Jul 19, 2010 4:20 pm Post subject: |
looks great...
Michael |
| Back to top |
Posted: Tue Jul 20, 2010 11:10 am Post subject: |
Thanks for the tips Ian. _________________ Please follow the 'WWW' link to my Photobucket pages with pics of some of my Discworld miniatures and dioramas. |
| Back to top |
michael Millegniumer Old Timer Author
Joined: 06 Nov 2004 Posts: 4248 Location: Alberta Canada
Posted: Fri Jul 23, 2010 2:48 pm Post subject: |
looks good Ian, just catching up on the forum. _________________ Regards Michael
http://users.xplornet.com/~macton/index.html |
| Back to top |
Posted: Fri Jul 23, 2010 10:46 pm Post subject: |
Thanks Michael, I'm echoing Andi & Gordon, but good to see that you're still about.
Credit where it's due and all that - for the wooden bits on the suitcase layout Michael's postings on the crane challenge thread have had several coats of looking-at. ( http://forum.gn15.info/viewtopic.php?t=5908&postdays=0&postorder=asc&start=225 , and scroll down a bit). At the moment I'm busy with the jetty, attacking bits of wood with wire brushes and things... _________________ Ian K
| Back to top |
Posted: Tue Jul 27, 2010 3:45 pm Post subject: |
| Quote: | | ...attacking bits of wood with wire brushes and things... |
...just common or garden stripwood and dowel from the DIY shop:
Basic painting done, and stuck together...
...and a close up:
Still needs more painting/weathering, and lots of bolt thingummies to make. It could probably do with a couple more longitudonal runners to support the deck too. (I know these are unrealistically long, forty two foot planks aren't exactly common, but when the deck is on only the ends will be visible.) _________________ Ian K
| Back to top |
Little Andi. GnatterBox Centurion Seasoned Campaigner Friend of Gn15.info
Joined: 04 May 2009 Posts: 391 Location: Leic's East-Mid's - UK.
Posted: Tue Jul 27, 2010 4:07 pm Post subject: |
Excellent beginning as ever Ian. Looks very solid and notably believable.
I'm already looking forward as to how you go about dressing it.
And of course stand by to have all your bestest ideas stolen - and remorselessly ta'boot, just tell yourself it's the sincerest form of flattery - it'll sting that little bit less!!!??
Cheers for now......... _________________ KBO .......................... Andi. |
| Back to top |
Moronguhl GnatterBox Centurion Raw Recruit
Joined: 11 Feb 2010 Posts: 205 Location: Kingston upon Thames, England
Posted: Tue Jul 27, 2010 4:15 pm Post subject: |
That wood looks great - nice and grey and weathered.
Are those Grandt Line bolts by any chance? I'm picking some up for loco detailing as they look very handy. _________________ Christian Summers
Great scott!
The beginnings of a brewery... |
| Back to top |
Posted: Wed Jul 28, 2010 7:39 am Post subject: |
Nice work Ian, its hard to believe that is going to fit into a suitcase
Your building quicker than me! _________________ Gordon F |
| Back to top |
Posted: Wed Jul 28, 2010 10:26 am Post subject: |
Thanks folks
Steal with impunity Andi, it's all stuff I've pilfered from other people anyway . Seriously, 'tis a good thing teh interweb when it comes to sharing techniques and ideas for models with like minded people, and generally getting a bit of feedback and chat about model making - when I started it was a bit of a solitary experience, just the monthly fix of Railway Modeller (49p if I remember rightly!) to see what other folk were up to.
Grandt line bolts sound tempting Christian, but these ones are hand knitted - a square of thin plasticard, a hexagon of thicker stuff then a bit of plastic rod. Cutting hexagonal pieces is a bit fiddly but they don't need to be super accurate - just put the better ones where they show most and encrust the miss-shapes in rust  _________________ Ian K
| Back to top |
Pandy GnatterBox Centurion Old Timer
Joined: 22 Nov 2007 Posts: 295 Location: West Midlands
Posted: Thu Jul 29, 2010 9:29 am Post subject: |
Ian, it's improving all the time ! love the stone blocks, well done ! the timber work is turning out really well too, the nuts & bolts are highly effective and it doesnt matter if they're not quite perfect, after being exposed to salt water all year round they would soon weather beyond recognition in some cases, can't wait to see the barnacles & limpets added, is the quayside going to be kelp free or like the lump of water between Douglas sea front and the Tower of Refuge? I remember getting stuck there in a rowing boat once (gawd that was a long time ago !) depends on the rise & fall levels of the tide I suppose. Keep it up, it's looking great already !  _________________ Dave & Lorraine, more ideas than space, time & finance permit ! |
| Back to top |
Posted: Thu Jul 29, 2010 1:26 pm Post subject: |
Thanks
I do like the idea of seaweed, barnacles etc.... perhaps some mud and rock uncovered at low tide... a few crabs scuttling about (ok, I'm getting carried away now ). Actually the treatment of the "sea" area inside the case lid is causing a bit of head scratching - there is certainly scope for interesting detail but how I go about it and still leave the sea wall removable so the case can close is going to require a bit of experimentation. I do want a fairly decayed look though, the jetty should look a bit newer than the quayside as it's meant to be a later addition, but I'm not really into new and shiny so in this case "newer" probably means "a bit less grotty"... _________________ Ian K
| Back to top |
Posted: Thu Jul 29, 2010 2:54 pm Post subject: |
A bit less grotty seems far more fitting than shiny & new, did think about crabs but thought no, better keep my gob shut ! I do remember Douglas harbour being a fantastically productive crab fishing spot when I was a kid, we did the boat trip out across the Menai Strait from Caernarfon and the landing stage for the boat, even though well used was covered in green slime and assorted marine life both animal and vegetable, will you be going for a Shearwater or two amongst the seagulls ? Eroded, corroded, encrusted and inhabited , make it mucky !  _________________ Dave & Lorraine, more ideas than space, time & finance permit ! |
| Back to top |
Posted: Thu Jul 29, 2010 3:09 pm Post subject: |
| Pandy wrote: | | Eroded, corroded, encrusted and inhabited |
Sounds good to me
Shearwaters? Hmmm, must admit I was looking at some seagulls this morning and thinking about milliput...  _________________ Ian K
| Back to top |
Posted: Thu Aug 05, 2010 4:31 pm Post subject: |
| Quote: | | ...must admit I was looking at some seagulls this morning and thinking about milliput... |
Shaped from milliput, painted with white enamel then poster paint (still needs feet). _________________ Ian K
| Back to top |
Posted: Thu Aug 05, 2010 7:47 pm Post subject: |
Nice job on the seagull !!!
Its a lot better that my efforts trying to make birds.
(yeah, I know you can buy them, but its not the same as the challenge of trying to make them yourself).  _________________ Glen Anthony.
Christchurch
New Zealand
| Back to top |
Adrian GnatterBox Centurion Seasoned Campaigner Friend of Gn15.info
Joined: 27 Apr 2009 Posts: 433 Location: Melbourne Australia
Posted: Fri Aug 06, 2010 2:05 am Post subject: |
G'day Ian
. | Quote: | | Actually the treatment of the "sea" area inside the case lid is causing a bit of head scratching - there is certainly scope for interesting detail but how I go about it and still leave the sea wall removable so the case can close is going to require a bit of experimentation. |
If you cover the base of the wall with "Glad Wrap" (that thin self adhesive kitchen plastic film that seems to have a life of its own ) and after putting the wall into position, add the sea using the method that I used on "trips around the lighthouse", for example http://forum.gn15.info/viewtopic.php?t=5362&postdays=0&postorder=asc&start=0 ..........the advantage of using the sealer that I used is that it remains flexible and doesn't crack if it moves slightly. If you want to add a 'beach section' for your 'intresting detail' that can also be added, using plaster or similar, before removing the wall.
It should then be possible to remove the wall and the plastic leaving a custom cast 'slot' for it.
By the way love the jetty. It is inspiring me to have a go at the pier railway that I want to have a go at. Also like the gull.......how long did it take to make.....just think that you only need another 20 or 30.......
Cheers _________________ Adrian Hoad
I might be daft but not stupid. |
| Back to top |
